Datasheet LT6604-5 (Analog Devices) - 3
ОписаниеDual Very Low Noise, Differential Amplifier and 5MHz Lowpass Filter
Страниц / Страница16 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 192 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
27 предложений от 18 поставщиков
Рутоника
LT6604CUFF-5#TRPBF
655 ₽
ЧипСити
LT6604CUFF-5#PBF
660 ₽
Эиком
LT6604CUFF-5#PBF
от 1 965 ₽
Элитан
LT6604CUFF-5
2 005 ₽
LT6604-5
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. Unless otherwise specifi ed VS = 5V (V+ = 5V, V– = 0V), RIN = 806Ω, and RLOAD = 1k. PARAMETER CONDITIONS MIN TYP MAX UNITS
Filter Gain Either Channel, VS = 3V VIN = 2VP-P, fIN = DC to 260kHz –0.5 0 0.5 dB VIN = 2VP-P, fIN = 500kHz (Gain Relative to 260kHz) l –0.15 0 0.1 dB VIN = 2VP-P, fIN = 2.5MHz (Gain Relative to 260kHz) l –0.4 –0.1 0.3 dB VIN = 2VP-P, fIN = 4MHz (Gain Relative to 260kHz) l –0.7 –0.1 0.6 dB VIN = 2VP-P, fIN = 5MHz (Gain Relative to 260kHz) l –1.1 –0.2 0.8 dB VIN = 2VP-P, fIN = 15MHz (Gain Relative to 260kHz) l –28 –25 dB VIN = 2VP-P, fIN = 25MHz (Gain Relative to 260kHz) l –44 dB Matching of Filter Gain, VS = 3V VIN = 2VP-P, fIN = DC to 260kHz 0.05 0.7 dB VIN = 2VP-P, fIN = 500kHz (Gain Relative to 260kHz) l 0.005 0.1 dB VIN = 2VP-P, fIN = 2.5MHz (Gain Relative to 260kHz) l 0.01 0.2 dB VIN = 2VP-P, fIN = 4MHz (Gain Relative to 260kHz) l 0.03 0.5 dB VIN = 2VP-P, fIN = 5MHz (Gain Relative to 260kHz) l 0.05 0.6 dB VIN = 2VP-P, fIN = 15MHz (Gain Relative to 260kHz) l 0.15 1.8 dB VIN = 2VP-P, fIN = 25MHz (Gain Relative to 260kHz) l 0.1 2.8 dB Matching of Filter Phase, VS = 3V VIN = 2VP-P, fIN = 2.5MHz l 0.2 2 deg VIN = 2VP-P, fIN = 4MHz l 0.5 3 deg Filter Gain Either Channel, VS = 5V VIN = 2VP-P, fIN = DC to 260kHz –0.5 0 0.5 dB VIN = 2VP-P, fIN = 500kHz (Gain Relative to 260kHz) l –0.15 0 0.1 dB VIN = 2VP-P, fIN = 2.5MHz (Gain Relative to 260kHz) l –0.4 –0.1 0.3 dB VIN = 2VP-P, fIN = 4MHz (Gain Relative to 260kHz) l –0.7 –0.1 0.6 dB VIN = 2VP-P, fIN = 5MHz (Gain Relative to 260kHz) l –1.1 –0.2 0.8 dB VIN = 2VP-P, fIN = 15MHz (Gain Relative to 260kHz) l –28 –25 dB VIN = 2VP-P, fIN = 25MHz (Gain Relative to 260kHz) l –44 dB Matching of Filter Gain, VS = 5V VIN = 2VP-P, fIN = DC to 260kHz 0.05 0.7 dB VIN = 2VP-P, fIN = 500kHz (Gain Relative to 260kHz) l 0.005 0.1 dB VIN = 2VP-P, fIN = 2.5MHz (Gain Relative to 260kHz) l 0.01 0.2 dB VIN = 2VP-P, fIN = 4MHz (Gain Relative to 260kHz) l 0.03 0.5 dB VIN = 2VP-P, fIN = 5MHz (Gain Relative to 260kHz) l 0.05 0.6 dB VIN = 2VP-P, fIN = 15MHz (Gain Relative to 260kHz) l 0.15 1.8 dB VIN = 2VP-P, fIN = 25MHz (Gain Relative to 260kHz) l 0.1 2.8 dB Matching of Filter Phase, VS = 5V VIN = 2VP-P, fIN = 2.5MHz l 0.2 2 deg VIN = 2VP-P, fIN = 4MHz l 0.5 3 deg Filter Gain Either Channel, VS = ±5V VIN = 2VP-P, fIN = DC to 260kHz –0.6 –0.1 0.4 dB Filter Gain, RIN = 229Ω VIN = 0.5VP-P, fIN = DC to 260kHz VS = 3V 10.4 10.9 11.5 dB VS = 5V 10.3 10.8 11.4 dB VS = ±5V 10.1 10.7 11.3 dB Filter Gain Temperature Coeffi cient (Note 2) fIN = 260kHz, VIN = 2VP-P 780 ppm/°C Noise Noise BW = 10kHz to 5MHz, RIN = 806Ω 45 μVRMS Distortion (Note 4) VIN = 2VP-P, fIN = 1MHz, RL = 800Ω 2nd Harmonic 93 dBc 3rd Harmonic 96 dBc VIN = 2VP-P, fIN = 5MHz, RL = 800Ω 2nd Harmonic 66 dBc 3rd Harmonic 73 dBc Channel Separation (Note 9) VIN = 2VP-P, fIN = 1MHz –117 dB Differential Output Swing Measured Between OUT+ and OUT–, VOCM Shorted to VMID VS = 5V l 3.85 4.8 VP-P_DIFF VS = 3V l 3.85 4.8 VP-P_DIFF Input Bias Current Average of IN+ and IN– l –70 –30 μA 66045fa 3
