Datasheet LTC6404 (Analog Devices) - 8
Описание600MHz, Low Noise, High Precision Fully Differential Input/Output Amplifier/Driver
Страниц / Страница28 / 8 — LTC6404-1 TYPICAL PERFORMANCE CHARACTERISTICS. Active Supply Current vs. …
Формат / Размер файлаPDF / 347 Кб
LTC6404-1 TYPICAL PERFORMANCE CHARACTERISTICS. Active Supply Current vs. Shutdown Supply Current vs
LTC6404-1 TYPICAL PERFORMANCE CHARACTERISTICS Active Supply Current vs Shutdown Supply Current vs
LTC6404 - 600MHz, Low Noise, High Precision Fully Differential Input/Output Ampli?er/Driver
LTC6404CUD-2#TRPBF
140 ₽
LTC6404CUD-2#TRPBF
270 ₽
LTC6404CUD-2#TRPBF
LTC6404CUD-2#TRPBF
АЦП азиатских производителей
LTC6404
LTC6404-1 TYPICAL PERFORMANCE CHARACTERISTICS Active Supply Current vs Shutdown Supply Current vs Differential Voltage Offset (Input Temperature Temperature Referred) vs Temperature
30 0.5 1.0 VCM = VOCM = MID-SUPPLY VCM = VOCM = MID-SUPPLY 5 REPRESENTATIVE UNITS 0.8 VCM = VOCM = MID-SUPPLY 29 V 0.4 0.6 S = 3V VS = 5V V 0.4 28 S = 5V VS = 3V V 0.3 0.2 S = 2.7V (mV) (mA) 27 (mA) 0 V I CC S = 3V I CC 0.2 OSDIFFV –0.2 26 VS = 2.7V –0.4 –0.6 25 0.1 –0.8 24 0 –1.0 –75 –50 –25 0 25 50 75 100 125 150 –75 –50 –25 0 25 50 75 100 125 150 –75 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 64041 G01 64041 G02 64041 G03
Common Mode Voltage Offset vs Active Supply Current vs Supply SHDN Supply Current vs Supply Temperature Voltage and Temperature Voltage and Temperature
10 30 0.5 5 REPRESENTATIVE UNITS VCM = VOCM = TA = 125°C 8 VCM = VOCM = MID-SUPPLY MID-SUPPLY TA = 105°C V 25 SHDN = V+ T 6 S = 3V 0.4 A = 90°C TA = 75°C 4 TA = 50°C 20 TA = 25°C 2 0.3 TA = –10°C (mV) TA = 125°C T 0 (mA) 15 A = –45°C T (mA) A = 105°C TA = –60°C OSCM I CC T I CC V –2 A = 90°C 0.2 10 TA = 75°C –4 TA = 50°C T –6 A = 25°C 0.1 5 TA = –10°C –8 TA = –45°C VCM = VOCM = MID-SUPPLY TA = –60°C SHDN = V– –10 0 0 –75 –50 –25 0 25 50 75 100 125 150 0 1 2 3 4 5 0 1 2 3 4 5 TEMPERATURE (°C) VSUPPLY (V) VSUPPLY (V) 64041 G05 64041 G06 64041 G04
SHDN Pin Current vs SHDN Pin Supply Current vs SHDN Pin Small-Signal Frequency Voltage and Temperature Voltage and Temperature Response
0 30 5 V V CM = VOCM = MID-SUPPLY CM = VOCM = MID-SUPPLY VS = 3V CF = 0pF V V S = 3V S = 3V VS = 5V –5 25 0 CF = 1.8pF –10 20 –5 T T A = 125°C A = 125°C –15 T (mA) 15 T A = 105°C A = 105°C T I CC T A = 90°C A = 90°C GAIN (dB) –10 PIN CURRENT (μA) TA = 75°C –20 TA = 75°C 10 T TA = 50°C SHDN A = 50°C T T A = 25°C A = 25°C UNFILTERED OUTPUTS T –15 –25 TA = –10°C 5 A = –10°C VCM = VOCM = MID-SUPPLY T T A = –45°C A = –45°C TA = 25°C T T A = –60°C A = –60°C RF = RI = 100Ω, CF IN PARALLEL WITH RF –30 0 –20 0 0.5 1.0 1.5 2.0 2.5 3.0 0 0.5 1.0 1.5 2.0 2.5 3.0 10 100 1000 SHDN PIN VOLTAGE (V) SHDN PIN VOLTAGE (V) FREQUENCY (MHz) 64041 G07 64041 G08 64041 G09 6404f 8
