Datasheet LTC6406 (Analog Devices) - 4
Описание3GHz, Low Noise, Rail-to-Rail Input Differential Amplifier/Driver
Страниц / Страница24 / 4 — DC ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which …
Формат / Размер файлаPDF / 333 Кб
DC ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full
DC ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full
IC ADC DRIVER 16QFN. ADC Driver IC Data Acquisition 16-QFN-EP (3x3). Linear - Amplifiers - Special Purpose
LTC6406CUD#TRPBF
139 ₽
LTC6406CUD#TRPBF
269 ₽
LTC6406CUD#TRPBF
323 ₽
LTC6406CUD#TRPBF
LTC6406
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, VCM = VOCM = VICM = 1.25V, VSHDN = open, RBAL = 100k
Ω
, RI = 150
Ω
, RF = 150
Ω
(0.1% resistors), CF = 1.8pF (see Figure 1) unless otherwise noted. VS is defi ned as (V+ – V–). VOUTCM is defi ned as (V+OUT + V–OUT)/2. VICM is defi ned as (V+IN + V–IN)/2. VOUTDIFF is defi ned as (V+OUT – V–OUT). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
ISC Output Short-Circuit Current, +OUT/–OUT Pins (Note 10) l ±35 ±55 mA AVOL Large-Signal Open Loop Voltage Gain 90 dB VS Supply Voltage Range l 2.7 3.5 V IS Supply Current l 18 22 mA ISHDN Supply Current in Shutdown VSHDN = 0V l 300 500 μA RSHDN SHDN Pull-Up Resistor VSHDN = 0V to 0.5V l 60 100 140 kΩ VIL SHDN Input Logic Low l 0.4 0.7 V VIH SHDN Input Logic High l 2.25 2.55 V tON Turn-On Time 200 ns tOFF Turn-Off Time 50 ns
AC ELECTRICAL CHARACTERISTICS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, VCM = VOCM = VICM = 1.25V, VSHDN = open, RI = 150
Ω
, RF = 150
Ω
(0.1% resistors), CF = 1.8pF, RLOAD = 400
Ω
(see Figure 2) unless otherwise noted. VS is defi ned as (V+ – V–). VICM is defi ned as (V+IN + V–IN)/2. VOUTDIFF is defi ned as (V+OUT – V–OUT). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SR Slew Rate Differential Output 630 V/μS GBW Gain-Bandwidth Product fTEST = 30MHz 3 GHz f–3dB –3dB Frequency (See Figure 2) l 500 800 MHz 50MHz Distortion VOCM = 1.25V, VS = 3V Differential Input, VOUTDIFF = 2VP-P 2nd Harmonic –77 dBc (Note 13) 3rd Harmonic l –65 –55 dBc VOCM = 1.25V, VS = 3V, RLOAD = 800Ω 2nd Harmonic –85 dBc 3rd Harmonic –72 dBc VOCM = 1.25V, VS = 3V, RLOAD = 800Ω, RI = RF = 500Ω 2nd Harmonic –80 dBc 3rd Harmonic –69 dBc 50MHz Distortion VOCM = 1.25V, VS = 3V, RLOAD = 800Ω, Single-Ended Input, VOUTDIFF = 2VP-P RI = RF = 500Ω (Note 13) 2nd Harmonic –69 dBc 3rd Harmonic –73 dBc 3rd-Order IMD at 49.5MHz, 50.5MHz VOUTDIFF = 2VP-P Envelope, –65 dBc RLOAD = 800Ω OIP3 at 50MHz (Note 11) RLOAD = 800Ω 36.5 dBm tS Settling Time VOUTDIFF = 2V Step 1% Settling 7 ns 0.1% Settling 11 ns NF Noise Figure at 50MHz Shunt-Terminated to 50Ω, RS = 50Ω 14.1 dB ZIN = 200Ω (RI = 100Ω, RF = 300Ω) 7.5 dB 6406fc 4
