Datasheet LT1994 (Analog Devices) - 3
ОписаниеLow Noise, Low Distortion Fully Differential Input/Output Amplifier/Driver
Страниц / Страница20 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 232 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
44 предложений от 19 поставщиков
Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT1994CMS8#PBF Differential Amplifier, Low Distortion, 1 Amplifiers, 3mV, 1dB, 70MHz, -40℃, 85℃
Зенер
Россия и страны ТС
LT1994CMS8#TRPBF
от 208 ₽
LT1994CMS8#PBF
350 ₽
LT1994CMS8#PBF
МосЧип
LT1994CMS8
LT1994
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. V+ = 3V, V– = 0V, VCM = VOCM = VICM = mid-supply, VSHDN = OPEN, RI = RF = 499
Ω
, RL = 800
Ω
to a mid-supply voltage (See Figure 1) unless otherwise noted. VS is defi ned (V+ – V–). VOUTCM is defi ned as (V + + + + OUT + VOUT )/2. VICM is defi ned as (VIN + VIN )/2. VOUTDIFF is defi ned as (VOUT – VOUT ). VINDIFF is defi ned as (VIN – VIN ). C/I GRADES H/MP GRADES SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOSDIFF Differential Offset Voltage VS = 2.375V, VICM = VS/4 l ±2 ±2 mV (Input Referred) VS = 3V l ±2 ±2 mV VS = 5V l ±2 ±2 mV VS = ±5V l ±3 ±3 mV ΔVOSDIFF/ΔT Differential Offset Voltage Drift VS = 2.375V, VICM = VS/4 3 μV/°C (Input Referred) VS = 3V 3 μV/°C VS = 5V 3 μV/°C VS = ±5V 3 μV/°C IB Input Bias Current (Note 6) VS = 2.375V, VICM = VS/4 l –45 –18 –3 –45 –18 –3 μA VS = 3V l –45 –18 –3 –45 –18 –3 μA VS = 5V l –45 –18 –3 –45 –18 –3 μA VS = ±5V l –45 –18 –3 –45 –18 –3 μA IOS Input Offset Current (Note 6) VS = 2.375V, VICM = VS/4 l ±0.2 ±2 ±0.2 ±2 μA VS = 3V l ±0.2 ±2 ±0.2 ±2 μA VS = 5V l ±0.2 ±3 ±0.2 ±3 μA VS = ±5V l ±0.2 ±4 ±0.2 ±4 μA RIN Input Resistance Common Mode 700 700 kΩ Differential Mode 4.5 4.5 kΩ CIN Input Capacitance Differential 2 2 pF en Differential Input Referred Noise f = 50kHz 3 3 nV/√Hz Voltage Density in Input Noise Current Density f = 50kHz 2.5 2.5 pA/√Hz enVOCM Input Referred Common Mode Output f = 50kHz, VOCM Shorted to Ground 15 15 nV/√Hz Noise Voltage Density VICMR Input Signal Common Mode Range VS = 3V l 0 1.75 0 1.75 V (Note 7) VS = ±5V l –5 3.75 –5 3.75 V CMRRI Input Common Mode Rejection Ratio VS = 3V, ΔVICM = 0.75V l 55 85 55 85 dB (Note 8) (Input Referred) ΔVICM/ΔVOSDIFF CMRRIO Output Common Mode Rejection Ratio VS = 5V, ΔVOCM = 2V l 65 85 65 85 dB (Note 8) (Input Referred) ΔVOCM/ΔVOSDIFF PSRR Differential Power Supply Rejection VS = 3V to ±5V l 69 105 69 105 dB (Note 9) (ΔVS/ΔVOSDIFF) PSRRCM Output Common Mode Power Supply VS = 3V to ±5V l 45 70 45 70 dB (Note 9) Rejection (ΔVS/ΔVOSCM) GCM Common Mode Gain (ΔVOUTCM/ΔVOCM) VS = ±2.5V l 1 V/V Common Mode Gain Error VS = ±2.5V l –0.15 ±1 % 100 • (GCM – 1) BAL Output Balance (ΔVOUTCM/ΔVOUTDIFF) ΔVOUTDIFF = 2V Single-Ended Input l –65 –46 –65 –46 dB Differential Input l –71 –50 –71 –50 dB VOSCM Common Mode Offset Voltage VS = 2.375V, VICM = VS/4 l ±2.5 ±25 ±2.5 ±25 mV (VOUTCM – VOCM) VS = 3V l ±2.5 ±25 ±2.5 ±25 mV VS = 5V l ±2.5 ±30 ±2.5 ±30 mV VS = ±5V l ±2.5 ±40 ±2.5 ±40 mV 1994fb 3
