Datasheet LT6600-2.5 (Analog Devices) - 3
ОписаниеVery Low Noise, Differential Amplifi er and 2.5MHz Lowpass Filter
Страниц / Страница16 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 233 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating temperature
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating temperature
38 предложений от 23 поставщиков
LINEAR TECHNOLOGY LT6600CS8-2.5#PBF Differential Amplifier, Low Noise, 1 Amplifiers, 35 mV, 2.5 MHz, 0 C, 70 C
LT6600CS8-2.5#PBF
215 ₽
ЧипСити
LT6600CS8-2.5
243 ₽
727GS
LT6600CS8-2.5#PBF
от 660 ₽
ТаймЧипс
LT6600CS825
LT6600-2.5
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. Unless otherwise specifi ed VS = 5V (V+ = 5V, V– = 0V), RIN = 1580Ω, and RLOAD = 1k. PARAMETER CONDITIONS MIN TYP MAX UNITS
VIN = 2VP-P, fIN = 2.5MHz (Gain Relative to 260kHz) l –2.1 –0.9 0 dB VIN = 2VP-P, fIN = 7.5MHz (Gain Relative to 260kHz) l –34 –31 dB VIN = 2VP-P, fIN = 12.5MHz (Gain Relative to 260kHz) l –51 dB Filter Gain, VS = 5V VIN = 2VP-P, fIN = DC to 260kHz –0.5 –0.1 0.4 dB RIN = 1580Ω VIN = 2VP-P, fIN = 700kHz (Gain Relative to 260kHz) l –0.15 0 0.1 dB VIN = 2VP-P, fIN = 2.2MHz (Gain Relative to 260kHz) l –0.2 0.2 0.6 dB VIN = 2VP-P, fIN = 2.2MHz (Gain Relative to 260kHz) l –0.6 0.1 0.5 dB VIN = 2VP-P, fIN = 2.5MHz (Gain Relative to 260kHz) l –2.1 –0.9 0 dB VIN = 2VP-P, fIN = 7.5MHz (Gain Relative to 260kHz) l –34 –31 dB VIN = 2VP-P, fIN = 12.5MHz (Gain Relative to 260kHz) l –51 dB Filter Gain, VS = ±5V VIN = 2VP-P, fIN = DC to 260kHz –0.6 –0.1 0.4 dB Filter Gain, RIN = 402Ω VIN = 0.5VP-P, fIN = DC to 260kHz, VS = 3V 11.3 11.8 12.3 dB VIN = 0.5VP-P, fIN = DC to 260kHz, VS = 5V 11.3 11.8 12.3 dB VIN = 0.5VP-P, fIN = DC to 260kHz, VS = ±5V 11.2 11.7 12.2 dB Filter Gain Temperature Coeffi cient (Note 2) fIN = 260kHz, VIN = 2VP-P 780 ppm/°C Noise Noise BW = 10kHz to 2.5MHz 51 μVRMS Distortion (Note 4) 1MHz, 1VRMS, RL = 800Ω 2nd Harmonic 95 dBc 3rd Harmonic 88 dBc Differential Output Swing Measured Between Pins 4 and 5 VS = 5V l 8.8 9.3 VP-P DIFF VS = 3V l 5.1 5.5 VP-P DIFF Input Bias Current Average of Pin 1 and Pin 8 l –35 –15 μA Input Referred Differential Offset RIN = 1580Ω, Differential Gain = 1V/V VS = 3V l 5 25 mV VS = 5V l 5 30 mV VS = ±5V l 5 35 mV RIN = 402Ω, Differential Gain = 4V/V VS = 3V l 3 13 mV VS = 5V l 3 16 mV VS = ±5V l 3 20 mV Differential Offset Drift 10 μV/°C Input Common Mode Voltage (Note 3) Differential Input = 500mVP-P, VS = 3V l 0.0 1.5 V RIN ≥ 402Ω VS = 5V l 0.0 3.0 V VS = ±5V l –2.5 1.0 V Output Common Mode Voltage (Note 5) Differential Input = 2VP-P, VS = 3V l 1.0 1.5 V Pin 7 = Open VS = 5V l 1.5 3.0 V VS = ±5V l –1.0 2.0 V Output Common Mode Offset VS = 3V l –25 10 45 mV (with Respect to Pin 2) VS = 5V l –30 5 45 mV VS = ±5V l –55 –10 35 mV Common Mode Rejection Ratio 63 dB Voltage at VMID (Pin 7) VS = 5V (S8) l 2.46 2.51 2.55 V VS = 5V (DFN) l 2.45 2.51 2.56 V VS = 3V 1.5 V VMID Input Resistance l 4.3 5.7 7.7 kΩ VOCM Bias Current VOCM = VMID = VS /2 VS = 5V l –15 –3 μA VS = 3V l –10 –3 μA Power Supply Current VS = 3V, VS = 5V 26 30 mA VS = 3V, VS = 5V l 33 mA VS = ±5V l 28 36 mA 660025fe 3
