Datasheet LT1789-1, LT1789-10 (Analog Devices) - 9
ОписаниеMicropower, Single Supply Rail-to-Rail Output Instrumentation Amplifier
Страниц / Страница24 / 9 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
Формат / Размер файлаPDF / 339 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply over the temperature range of
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the temperature range of
37 предложений от 18 поставщиков
Микросхема Буферный усилитель, INST Amp 1 Rail to Rail Output ±18V/36V 8Pin SOIC N
LT1789IS8-10#PBF
LT1789IS8-10-TR
LT1789IS8-10 TRPBF
LifeElectronics
LT1789IS8-10#PBF
LT1789-1/LT1789-10
l
denotes the specifications which apply over the temperature range of –40°C ≤ TA ≤ 85°C. VS = ±15V, RL = 20k, VCM = VREF = 0V, unless otherwise noted. (Note 4) LT1789-1 LT1789-10 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
PSRR Power Supply Rejection Ratio LT1789-1, VS = ±1.25V to ±16V LT1789-10, VS = ±1.50V to ±16V G = 1 l 90 dB G = 10 l 100 96 dB G = 100, 1000 l 102 102 dB Minimum Supply Voltage l ±1.25 ±1.50 V IS Supply Current l 160 160 µA VO Output Voltage Swing l ±14.15 ±14.15 V SR Slew Rate VOUT = ±10V l 0.008 0.024 V/µs
Note 1:
Note 5:
Hysteresis in offset voltage is created by package stress that may cause permanent damage to the device. Exposure to any Absolute differs depending on whether the IC was previously at a higher or lower Maximum Rating condition for extended periods may affect device temperature. Offset voltage hysteresis is always measured at 25°C, but reliability and lifetime. the IC is cycled to 85°C I-grade (or 70°C C-grade) or – 40°C I-grade
Note 2:
Does not include the effect of the external gain resistor R (0°C C-grade) before successive measurement. 60% of the parts will G.
Note 3:
This parameter is not 100% tested. pass the typical limit on the data sheet.
Note 4:
The LT1789C-1/ LT1789C-10 is guaranteed to meet specified
Note 6:
VS = 5V limits are guaranteed by correlation to VS = 3V and performance from 0°C to 70°C and is designed, characterized and VS = ±15V tests. expected to meet these extended temperature limits, but is not tested at
Note 7:
VS = 3V limits are guaranteed by correlation to VS = 5V and –40°C and 85°C. The LT1789I-1/ LT1789I-10 is guaranteed to meet the VS = ±15V tests. extended temperature limits.
Note 8:
This parameter is not tested at VS = 3V on the LT1789-10 due to an increase in sensitivity to test system noise. Actual performance is expected to be similar to performance at VS = 5V.
TYPICAL PERFORMANCE CHARACTERISTICS (LT1789-1, LT1789-10) Input Bias Current Input Bias Current Supply Current vs Supply Voltage vs Temperature vs Common Mode Input Voltage
120 0 –10 VS = 5V, 0V –55°C 110 V –12 CM = 2.5V 100 –5 –14 125°C 125°C 90 –16 80 –10 –18 25°C 25°C 70 –20 85°C 60 –55°C –15 –22 50 –24 SUPPLY CURRENT (μA) INPUT BIAS CURRENT (nA) INPUT BIAS CURRENT (nA) 40 –20 –26 30 –28 VS = 5V, 0V VREF = 2.5V 20 –25 –30 0 5 10 15 20 25 30 35 40 –50 –25 0 25 50 75 100 125 –0.5 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 TOTAL SUPPLY VOLTAGE (V) TEMPERATURE (°C) COMMON MODE INPUT VOLTAGE (V) 1789 G01 1789 G02 1789 G03 1789fc 9
