Datasheet LTC1100 (Analog Devices) - 2
ОписаниеPrecision, Zero-Drift Instrumentation Amplifier
Страниц / Страница8 / 2 — ABSOLUTE AXI U RATI GS (Note 1). (OBSOLETE). PACKAGE/ORDER I FOR ATIO. …
Формат / Размер файлаPDF / 143 Кб
ABSOLUTE AXI U RATI GS (Note 1). (OBSOLETE). PACKAGE/ORDER I FOR ATIO. OBSOLETE PACKAGE. ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS (Note 1) (OBSOLETE) PACKAGE/ORDER I FOR ATIO OBSOLETE PACKAGE ELECTRICAL CHARACTERISTICS The
35 предложений от 18 поставщиков
LTC1100CN8
83 ₽
LTC1100CN8#PBF
от 318 ₽
ЗУМ-СМД
LTC1100CN8#PBF
LTC1100CN8PBF
LTC1100
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Operating Temperature Range Storage Temperature Range .. −65°C to 150°C LTC1100M/AM
(OBSOLETE)
... −55°C to 125°C Total Supply Voltage (V+ to V−) ... 18V LTC1100C ... −40°C to 85°C Input Voltage ... (V+ + 0.3V) to (V− − 0.3V) Output Short Circuit Duration ... Indefinite Lead Temperature (Soldering, 10 sec)... 300°C
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW ORDER PART ORDER PART TOP VIEW GND REF 1 8 VOUT NUMBER NUMBER NC 1 16 NC CMRR 2 7 COMP GND REF 2 15 V LTC1100CN8 OUT LTC1100CSW –V 3 IN 6 VIN G = 10 3 14 G = 10 V– 4 5 V+ CMRR 4 13 COMP N8 PACKAGE NC 5 12 NC 8-LEAD PDIP –V 6 11 IN VIN TJMAX = 110°C, θJA = 130°C/W V– 7 10 V+ J PACKAGE LTC1100CJ8 NC 8 9 NC 8-LEAD CERDIP T LTC1100AMJ8 JMAX = 150°C, θJA = 100°C/W SW PACKAGE LTC1100MJ8 16-LEAD PLASTIC SO WIDE TJMAX = 110°C, θJA = 100°C/W
OBSOLETE PACKAGE
Consider the N Package for an Alternate Source Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VS =
5V, RL = 10k, CC = 1000pF, unless otherwise noted. LTC1100ACN LTC1100CN/CJ PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Gain Error 0.01 0.05 0.01 0.075 ±% ● 0.10 0.150 ±% Gain Nonlinearity 3 8 3 20 ppm ● 12 30 12 60 ppm Input Offset Voltage (Note 2) ±1 ±10 ±1 ±10 µV Input Offset Voltage Drift (Note 2) ● ±5 ±100 ±5 ±100 nV/°C Input Noise Voltage DC to 10Hz, TA = 25°C 1.9 1.9 µVP-P Input Bias Current 2.5 50 2.5 65 pA ● 120 135 pA Input Offset Current ● 10 50 10 65 pA Common Mode Rejection Ratio VCM = 2.3V to −4.7V (Note 3) ● 104 115 90 110 dB Power Supply Rejection Ratio VS = ±2.375V to ±8V ● 120 105 dB Output Voltage Swing RL = 2k, VS = ±8V ● – 7.2 6.2 – 7.2 6.2 V RL =10k, VS = ±8V ● – 7.7 7.5 – 7.7 7.5 V Supply Current 2.4 2.8 2.4 3.3 mA ● 3.4 4.0 3.4 4.5 mA Internal Sampling Frequency 2.8 2.8 kHz Bandwidth 18 18 kHz 1100fc 2
