Оптопары и оптореле Megawin
Datasheet LT6210, LT6211 (Analog Devices) - 3
ОписаниеSingle Programmable Supply Current, R-R Output, Current Feedback Amplifiers
Страниц / Страница18 / 3 — e lecTrical characTerisTics (IS = 6mA per Amplifier) The. denotes the …
Формат / Размер файлаPDF / 354 Кб
e lecTrical characTerisTics (IS = 6mA per Amplifier) The. denotes the specifications which
e lecTrical characTerisTics (IS = 6mA per Amplifier) The denotes the specifications which
39 предложений от 16 поставщиков
727GS
LT6210IS6#TRPBF
от 686 ₽
Microfind
LT6210IS6#TRPBF
865 ₽
LT6210IS6#TRPBF
SUV System
LT6210IS6#TRPBF
Ruimeng предлагает удачную замену популярной микросхеме Axx1248 – 24-битный Σ-Δ АЦП MS5148T
LT6210/LT6211
l
denotes the specifications which apply over the specified operating temperature range, otherwise specifications are at TA = 25°C. For V+ = 5V, V– = –5V: RSET = 20k to ground, AV = +2, RF = RG = 887Ω, RL = 150Ω; For V+ = 3V, V– = 0V: RSET = 0Ω to V–, AV = +2, RF = 887Ω, RG = 887Ω to 1.5V, RL = 150Ω to 1.5V unless otherwise specified. V+ = 5V, V– = –5V, IS = 6mA V+ = 3V, V– = 0V, IS = 6mA SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage –1 ±6 –1 ±6.5 mV l ±9 ±10 mV I + IN Noninverting Input Current –3.5 ±7 –3 ±6.5 µA l ±9 ±8 µA I – IN Inverting Input Current –13.5 ±39 2.5 ±25 µA l ±55 ±40 µA en Input Noise Voltage Density f = 1kHz, RF = 887Ω, 6.5 6.5 nV/√Hz RG = 46.4Ω, RS = 0Ω +in Input Noise Current Density f = 1kHz 4.5 4.5 pA/√Hz –in Input Noise Current Density f = 1kHz 25 25 pA/√Hz R + IN Noninverting Input Resistance VIN = V+ – 1.2V to V– + 1.2V l 0.5 2 0.3 1.7 MΩ C + IN Noninverting Input Capacitance f = 100kHz 2 2 pF VINH Input Voltage Range, High (Note 10) l 3.8 4.2 1.8 2.2 V VINL Input Voltage Range, Low (Note 10) l –4.2 –3.8 0.8 1.2 V VOUTH Output Voltage Swing, High RL = 1k (Note 11) 4.8 2.85 V RL = 150Ω (Note 11) 4.4 4.6 2.65 2.75 V RL = 150Ω (Note 11) l 4.2 2.6 V VOUTL Output Voltage Swing, Low RL = 1k (Note 11) –4.95 0.05 V RL = 150Ω (Note 11) –4.8 –4.55 0.1 0.3 V RL = 150Ω (Note 11) l –4.4 0.35 V CMRR Common Mode Rejection Ratio VIN = V+ – 1.2V to V– + 1.2V 46 50 46 dB l 43 dB –ICMRR Inverting Input Current VIN = V+ – 1.2V to V– + 1.2V 0.15 ±1.5 0.2 µA/V Common Mode Rejection l ±2 µA/V PSRR Power Supply Rejection Ratio VS = ±1.5V to ±6V (Note 6) l 60 85 60 85 dB –IPSRR Inverting Input Current Power VS = ±1.5V to ±6V (Note 6) 2 ±7 2 ±7 µA/V Supply Rejection l ±8 ±8 µA/V IS Supply Current per Amplifier 6 8.5 5.8 8.3 mA l 10 9 mA 62101fc 3 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical AC Performance Typical Performance Characteristics Applications Information Typical Applications Simplified Schematic Package Description Revision History Typical Application Related Parts
