Datasheet LT1795 (Analog Devices) - 2
ОписаниеDual 500mA/50MHz Current Feedback Line Driver Amplifier
Страниц / Страница12 / 2 — ABSOLUTE AXI U. RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL …
Формат / Размер файлаPDF / 158 Кб
ABSOLUTE AXI U. RATI GS (Note 1). PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHARACTERISTICS The
ABSOLUTE AXI U RATI GS (Note 1) PACKAGE/ORDER I FOR ATIO ELECTRICAL CHARACTERISTICS The
36 предложений от 21 поставщиков
Микросхема Буферный усилитель, IC OPAMP CFA 65MHz 20SO
Зенер
Россия и страны ТС
LT1795CSW
от 1 370 ₽
LT1795CSW#PBF
от 1 669 ₽
Эиком
LT1795CSW#PBF
от 1 755 ₽
МосЧип
LT1795CSW(ICS)
LT1795
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Supply Voltage .. ±18V Specified Temperature Range (Note 3) ... – 40°C to 85°C Input Current .. ±15mA Junction Temperature ... 150°C Output Short-Circuit Duration (Note 2) .. Indefinite Storage Temperature Range ... – 65°C to 150°C Operating Temperature Range .. – 40°C to 85°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW ORDER PART TOP VIEW ORDER PART V– 1 20 V– NUMBER COMP 1 20 COMP NUMBER NC 2 19 NC V+ 2 19 V+ LT1795CFE LT1795CSW –IN 3 18 OUT OUT 3 18 OUT +IN 4 17 V+ LT1795IFE LT1795ISW V– 4 17 V– SHDN 5 16 COMP V– 5 16 V– SHDNREF 6 15 COMP V– 6 15 V– +IN 7 14 V+ V– 7 14 V– –IN 8 13 OUT –IN 8 13 –IN NC 9 12 NC +IN 9 12 +IN V– 10 11 V– SHDN 10 11 SHDNREF FE PACKAGE S PACKAGE 20-LEAD PLASTIC TSSOP 20-LEAD PLASTIC SW TJMAX = 150° C, θJA = 40°C/W (Note 4) TJMAX = 150° C, θJA ≈ 40°C/W (Note 4) UNDERSIDE METAL INTERNALLY CONNECTED TO V– (PCB CONNECTION OPTIONAL) Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes the specifications which apply over the full specified temperature range, otherwise specifications are at TA = 25
C. VCM = 0V,
5V
VS
15V, pulse tested, VSHDN = 2.5V, VSHDNREF = 0V unless otherwise noted. (Note 3) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage ±3 ±13 mV ● ±4.5 ±17 mV Input Offset Voltage Matching ±1 ±3.5 mV ● ±1.5 ±5.0 mV Input Offset Voltage Drift ● 10 µV/°C I + IN Noninverting Input Current ±2 ±5 µA ● ±8 ±20 µA Noninverting Input Current Matching ±0.5 ±2 µA ● ±1.5 ±7 µA I – IN Inverting Input Current ±10 ±70 µA ● ±20 ±100 µA Inverting Input Current Matching ±10 ±30 µA ● ±20 ±50 µA en Input Noise Voltage Density f = 10kHz, RF =1k, RG = 10Ω, RS = 0Ω 3.6 nV/√Hz + in Input Noise Current Density f = 10kHz, RF =1k, RG = 10Ω, RS = 10kΩ 2 pA/√Hz – in Input Noise Current Density f = 10kHz, RF =1k, RG = 10Ω, RS = 10kΩ 30 pA/√Hz 1795fa 2
