Datasheet LT1223 (Analog Devices) - 4
Описание100MHz Current Feedback Amplifier
Страниц / Страница16 / 4 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
Формат / Размер файлаPDF / 258 Кб
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
11 предложений от 10 поставщиков
Микросхема Буферный усилитель, IC OPAMP CFA 100MHz 8SO
LT1223CS8#TRPBF
287 ₽
LT1223CS8#TRPBF
300 ₽
LT1223CS8#TRPBF
от 351 ₽
LT1223CS8#TRPBF
LT1223
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at VS =
15V, VCM = 0V, – 55
C
TA
125
C, unless otherwise noted. LT1223M SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = 0V ● ±1 ±5 mV I + IN Noninverting Input Current VCM = 0V ● ±1 ±5 µA I – IN Inverting Input Current VCM = 0V ● ±1 ±10 µA RIN Input Resistance VIN = ±10V ● 1 10 MΩ Input Voltage Range ● ±10 ±12 V CMRR Common Mode Rejection Ratio VCM = ±10V ● 56 63 dB Inverting Input Current Common Mode Rejection VCM = ±10V ● 30 100 nA/V PSRR Power Supply Rejection Ratio VS = ±4.5V to ±15V ● 68 80 dB Noninverting Input Current Power Supply Rejection VS = ±4.5V to ±15V ● 12 200 nA/V Inverting Input Current Power Supply Rejection VS = ±4.5V to ±15V ● 60 500 nA/V AV Large-Signal Voltage Gain RLOAD = 400Ω, VOUT = ±10V ● 70 89 dB ROL Transresistance, ∆VOUT/∆IIN– RLOAD = 400Ω, VOUT = ±10V ● 1.5 5 MΩ VOUT Maximum Output Voltage Swing RLOAD = 200Ω ● ±7 ±12 V IOUT Maximum Output Current RLOAD = 200Ω ● 35 60 mA IS Supply Current VIN = 0V ● 6 10 mA Supply Current, Shutdown Pin 8 Current = 200µA ● 2 4 mA
Note 1:
Absolute Maximum Ratings are those values beyond which the life of a device may be impaired.
Note 2:
A heat sink may be required.
Note 3:
Noninverting operation, VOUT = ±10V, measured at ±5V. 1223fb 4
