Datasheet LT1358, LT1359 (Analog Devices) - 8
ОписаниеDual and Quad 25MHz, 600V/µs Op Amps
Страниц / Страница16 / 8 — TYPICAL PERFOR A CE CHARACTERISTICS. Power Supply Rejection Ratio. Common …
Формат / Размер файлаPDF / 489 Кб
TYPICAL PERFOR A CE CHARACTERISTICS. Power Supply Rejection Ratio. Common Mode Rejection Ratio. Gain and Phase vs Frequency
TYPICAL PERFOR A CE CHARACTERISTICS Power Supply Rejection Ratio Common Mode Rejection Ratio Gain and Phase vs Frequency
32 предложений от 15 поставщиков
727GS
LT1359IN#PBF
от 254 ₽
LT1359IN#PBF
1 128 ₽
Рутоника
LT1359IN#PBF
1 467 ₽
Элитан
LT1359IN
2 701 ₽
LT1358/LT1359
W U TYPICAL PERFOR A CE CHARACTERISTICS Power Supply Rejection Ratio Common Mode Rejection Ratio Gain and Phase vs Frequency vs Frequency vs Frequency
70 120 100 120 +PSRR V V S = ±15V S = ±15V 60 PHASE 100 – PSRR T T A = 25°C A = 25°C 100 PHASE (DEG) 80 50 VS = ±15V 80 VS = ±15V 80 40 60 GAIN 60 VS = ±5V 30 40 60 VS = ±5V GAIN (dB) 20 20 40 40 10 0 TA = 25°C 20 20 0 AV = –1 R POWER SUPPLY REJECTION RATIO (dB) COMMON-MODE REJECTION RATIO (dB) F = RG = 2k –10 0 0 10k 100k 1M 10M 100M 100 1k 10k 100k 1M 10M 100M 1k 10k 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) 135859 G14 135859 G20 135859 G21
Slew Rate vs Supply Voltage Slew Rate vs Temperature Slew Rate vs Input Level
1000 600 1000 T T A = 25°C A = 25°C V 900 S = ±15V V A S = ±15V 500 800 V = –1 A R 800 V = –1 F = RG = 2k AV = –2 RF = RG = 2k SR+ + SR– SR+ + SR– 700 SR+ + SR– µs) SR = ————— 400 SR = ————— SR = ————— 2 µs) µs) 600 2 600 2 300 500 400 400 SLEW RATE (V/ SLEW RATE (V/ 200 SLEW RATE (V/ 300 VS = ±5V 200 200 100 100 0 0 0 0 5 10 15 – 50 –25 0 25 50 75 100 125 0 2 4 6 8 10 12 14 16 18 20 SUPPLY VOLTAGE (±V) TEMPERATURE (°C) INPUT LEVEL (VP-P) 135859 G22 135859 G23 135859 G24
Total Harmonic Distortion Undistorted Output Swing vs Undistorted Output Swing vs vs Frequency Frequency (
15V) Frequency (
5V)
0.01 30 10 T A A = 25°C V = –1 VO = 3VRMS 25 RL = 2k 8 A ) V = –1 A P-P V = 1 P-P 20 AV = 1 A 6 V = –1 0.001 15 4 AV = 1 10 OUTPUT VOLTAGE (V VS = ±15V OUTPUT VOLTAGE (V R 2 V 5 L = 2k S = ±5V TOTAL HARMONIC DISTORTION (%) AV = 1, 1% MAX DISTORTION RL = 2k AV = –1, 2% MAX DISTORTION 2% MAX DISTORTION 0.0001 0 0 10 100 1k 10k 100k 100k 1M 10M 100k 1M 10M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) 135859 G25 135859 G26 135859 G27 135859fb 8
