Datasheet LT6203X (Analog Devices) - 10
ОписаниеHigh Temperature 175°C Dual 100MHz, Rail-to-Rail Input and Output, Ultralow 1.9nV/√Hz Noise, Low Power Op Amp
Страниц / Страница16 / 10 — Typical perForMance characTerisTics. Gain Bandwidth and Phase. Margin vs …
Формат / Размер файлаPDF / 1.8 Мб
Typical perForMance characTerisTics. Gain Bandwidth and Phase. Margin vs Supply Voltage. Slew Rate vs Temperature
Typical perForMance characTerisTics Gain Bandwidth and Phase Margin vs Supply Voltage Slew Rate vs Temperature
Рутоника
LT6203XS8#TRPBF
7 737 ₽
LT6203XS8#PBF
11 595 ₽
LT6203XS8#PBF
11 600 ₽
LT6203XS8#PBF
от 20 283 ₽
LT6203X
Typical perForMance characTerisTics Gain Bandwidth and Phase Margin vs Supply Voltage Slew Rate vs Temperature Output Impedance vs Frequency
90 80 1000 TA = 25°C AV = –1 VS = 5V, 0V RL = 1k 80 R 70 F = RG = 1k CL = 5pF PHASE MARGIN R RISING L= 1k 100 70 PHASE MARGIN (DEG) 60 AV = 10 60 /µs) 50 10 AV = 2 50 TE (V 120 GAIN BANDWIDTH 40 FALLING 100 30 1 SLEW RA GAIN BANDWITH (MHz) 80 20 V A S = ±5V OUTPUT IMPEDANCE (Ω) V = 1 V 0.1 S = ±2.5V 60 10 VS = ±5V VS = ±2.5V 40 0 0.01 0 2 4 6 8 10 12 14 –50 –25 0 25 50 75 100 125 150 175 100k 1M 10M 100M TOTAL SUPPLY VOLTAGE (V) TEMPERATURE (°C) FREQUENCY (Hz) 6203X G27 6203X G26 6203X G28
Common Mode Rejection Ratio Power Supply Rejection Ratio vs Frequency Channel Separation vs Frequency vs Frequency
120 –40 80 VS = 5V, 0V TA = 25°C VS = 5V, 0V VCM = VS/2 –50 AV = 1 70 TA = 25°C 100 VS = ±5V VCM = VS/2 TIO (dB) –60 TIO (dB) 60 80 –70 50 POSITIVE 60 –80 40 SUPPLY TAGE GAIN (dB) –90 30 40 VOL –100 NEGATIVE 20 SUPPLY 20 –110 10 COMMON MODE REJECTION RA COMMON MODE REJECTION RA 0 –120 0 10k 100k 1M 10M 100M 1G 0.1 1 10 100 1k 10k 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (MHz) FREQUENCY (Hz) 6203X G29 6203X G30 6203X G31
Series Output Resistor Series Output Resistor vs Capacitive Load vs Capacitive Load
40 40 VS = 5V, 0V VS = 5V, 0V 35 AV = 1 35 AV = 2 RS = 10Ω 30 R 30 S = 10Ω RS = 20Ω 25 25 20 R 20 S = 20Ω RS = 50Ω 15 15 RL = 50Ω OVERSHOOT (%) OVERSHOOT (%) 10 RS = 50Ω 10 RL = 50Ω 5 5 0 0 10 100 1000 10 100 1000 CAPACITIVE LOAD (pF) CAPACITIVE LOAD (pF) 6203X G32 6203X G33 6203xf 10 For more information www.linear.com/LT6203X Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Electrical Characteristics Typical Performance Characteristics Applications Information Typical Application Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Applications Information Package Description Typical Application Related Parts
