Datasheet RH6200M (Analog Devices) - 5
ОписаниеLow Noise, High Speed Rail-to-Rail Op Amp
Страниц / Страница10 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS. Offset Voltage vs Input Common. …
Формат / Размер файлаPDF / 158 Кб
TYPICAL PERFORMANCE CHARACTERISTICS. Offset Voltage vs Input Common. Input Bias Current. Output Saturation Voltage
TYPICAL PERFORMANCE CHARACTERISTICS Offset Voltage vs Input Common Input Bias Current Output Saturation Voltage
RH6200MW:62
RH6200M
TYPICAL PERFORMANCE CHARACTERISTICS Offset Voltage vs Input Common Input Bias Current Output Saturation Voltage Mode Voltage vs Common Mode Voltage vs Load Current (Output Low)
3.0 20 10 VS = 5V, 0V VS = 5V, 0V VS = 5V, 0V 2.5 TYPICAL PART 10 2.0 1 1.5 0 TA = 125°C 1.0 –10 0.1 0.5 T T A = 125°C A = 25°C 0 –20 TA = –55°C TA = –55°C OFFSET VOLTAGE (mV) 0.01 –0.5 TA = –55°C INPUT BIAS CURRENT (μA) T T A = 25°C A = 25°C –30 –1.0 T OUTPUT SATURATION VOLTAGE (V) A = 125°C –1.5 –40 0.001 0 1 2 3 4 5 –1 0 1 2 3 4 5 6 0.1 1 10 100 INPUT COMMON MODE VOLTAGE (V) COMMON MODE VOLTAGE (V) LOAD CURRENT (mA) RH6200 G05 RH6200 G06 RH6200 G04
Output Saturation Voltage Supply Current vs Load Current (Output High) Input Noise Voltage vs Frequency vs SHDN Pin Voltage
10 45 22 VS = 5V, 0V VS = 5V, 0V VS = 5V, 0V 40 T 20 A = 25°C PNP ACTIVE 18 ) 35 Hz V T CM = 0.5V A = 125°C 16 1 30 14 T 25 A = 25°C 12 NPN ACTIVE 20 10 V T CM = 4.5V A = 125°C 8 0.1 15 BOTH ACTIVE NOISE VOLTAGE (nV/√ SUPPLY CURRENT (mA) 6 TA = 25°C 10 VCM = 2.5V TA = –55°C 4 OUTPUT SATURATION VOLTAGE (V) TA = –55°C 5 2 0.01 0 0 0.1 1 10 100 10 100 1k 10k 100k 0 1 2 3 4 5 LOAD CURRENT (mA) FREQUENCY (Hz) SHDN PIN VOLTAGE (V) RH6200 G07 RH6200 G08 RH6200 G09
SHDN Pin Current Gain Bandwidth and Phase vs SHDN Pin Voltage Margin vs Temperature
50 70 VS = 5V, 0V VS = ±5V 60 0 VS = 5V, 0V T 50 A = 25°C PHASE MARGIN (DEG) –50 PHASE MARGIN TA = –55°C 40 –100 TA = 125°C VS = ±5V –150 180 PIN CURRENT (μA) 160 –200 SHDN VS = 5V, 0V GAIN BANDWIDTH (MHz) 140 –250 GAIN BANDWIDTH 120 –300 100 0 1 2 3 4 5 –50 –25 0 25 50 75 100 125 SHDN PIN VOLTAGE (V) TEMPERATURE (°C) RH6200 G10 RH6200 G11 rh6200mfa 5
