Datasheet LT1469-2 (Analog Devices) - 2
ОписаниеDual 200MHz, 30V/μs 16-Bit Accurate AV ≥ 2 Op Amp
Страниц / Страница12 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. …
Формат / Размер файлаPDF / 201 Кб
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
21 предложений от 15 поставщиков
LT1469AIDF-2#TRPBF
565 ₽
Эиком
LT1469AIDF-2#PBF
от 1 674 ₽
Элитан
LT1469AIDF-2
1 675 ₽
LT1469AIDF-2#TRPBF
LT1469-2
Total Supply Voltage (V + to V–) ...36V Specifi ed Temperature Range (Note 5) .. –40°C to 85°C Input Current (Note 2) ..±10mA Maximum Junction Temperature... 150°C Output Short-Circuit Duration (Note 3) .. Indefi nite Storage Temperature Range ... –65°C to 150°C Operating Temperature Range (Note 4).. –40°C to 85°C
PIN CONFIGURATION
TOP VIEW TOP VIEW OUT A 1 12 V+ –IN A 2 11 OUT B OUT A 1 8 V+ A +IN A 3 10 –IN B 13 B –IN A 2 7 OUT B V– 4 9 +IN B A +IN A 3 6 –IN B N/C 5 8 N/C B V– 4 5 +IN B N/C 6 7 N/C DF PACKAGE S8 PACKAGE 12-LEAD (4mm × 4mm) PLASTIC DFN 8-LEAD PLASTIC SO T T JMAX = 150°C, θJA = 37°C/W JMAX = 150°C, θJA = 190°C/W EXPOSED PAD (PIN 13) IS GND, MUST BE CONNECTED TO V–
PACKAGE DESCRIPTION TEMPERATURE RANGE
LT1469CS8-2#PBF LT1469CS8-2#TRPBF 14692 8-Lead Plastic Small Outline 0°C to 70°C LT1469IS8-2#PBF LT1469IS8-2#TRPBF 14692 8-Lead Plastic Small Outline –40°C to 85°C LT1469ACDF-2#PBF LT1469ACDF-2#TRPBF 14692 12-Lead (4mm × 4mm) Plastic DFN 0°C to 70°C LT1469AIDF-2#PBF LT1469AIDF-2#TRPBF 14692 12-Lead (4mm × 4mm) Plastic DFN –40°C to 85°C LT1469CDF-2#PBF LT1469CDF-2#TRPBF 14692 12-Lead (4mm × 4mm) Plastic DFN 0°C to 70°C LT1469IDF-2#PBF LT1469IDF-2#TRPBF 14692 12-Lead (4mm × 4mm) Plastic DFN –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/
ELECTRICAL CHARACTERISTICS The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
VOS Input Offset Voltage S8 Package ±15V 50 125 μV ±5V 50 200 μV LT1469A, DF Package ±15V 50 125 μV ±5V 50 200 μV LT1469, DF Package ±15V 100 225 μV ±5V 150 300 μV IOS Input Offset Current ±5V to ±15V 13 ±50 nA 14692f 2
