Datasheet LT1469-2 (Analog Devices) - 3
ОписаниеDual 200MHz, 30V/μs 16-Bit Accurate AV ≥ 2 Op Amp
Страниц / Страница12 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 201 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
Микросхема Буферный усилитель, Dual 200MHz, 30V/µs 16Bit Accurate AV ≥ 2 Op Amp
LT1469CS8-2#TRPBF
593 ₽
LT1469CS8-2#TRPBF
609 ₽
TradeElectronics
LT1469CS8-2#TRPBF
LT1469CS8-2 TRPBF
LT1469-2
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
IB– Inverting Input Bias Current ±5V to ±15V 3 ±10 nA IB+ Noninverting Input Bias Current ±5V to ±15V –10 ±40 nA Input Noise Voltage 0.1Hz to 10Hz ±5V to ±15V 0.3 μVP-P en Input Noise Voltage Density f = 10kHz ±5V to ±15V 5 nV/√Hz in Input Noise Current Density f = 10kHz ±5V to ±15V 0.6 pA/√Hz RIN Input Resistance Common Mode, VCM = ±12.5V ±15V 100 240 MΩ Differential ±15V 50 150 kΩ CIN Input Capacitance ±15V 4 pF VCM Input Voltage Range (Positive) Guaranteed by CMRR ±15V 12.5 13.5 V ±5V 2.5 3.6 V Input Voltage Range (Negative) Guaranteed by CMRR ±15V –14.3 –12.5 V ±5V –4.4 –2.5 V CMRR Common Mode Rejection Ratio VCM = ±12.5V ±15V 96 110 dB VCM = ±2.5V ±5V 96 112 dB Minimum Supply Voltage Guaranteed by PSRR ±2.5 ±4.5 V PSRR Power Supply Rejection Ratio VS = ±4.5V to ±15V 100 112 dB AVOL Large-Signal Voltage Gain VOUT = ±12.5V, RL = 10k ±15V 300 2000 V/mV VOUT = ±12.5V, RL = 2k ±15V 300 2000 V/mV VOUT = ±2.5V, RL = 10k ±5V 200 8000 V/mV VOUT = ±2.5V, RL = 2k ±5V 200 8000 V/mV VOUT Maximum Output Swing RL = 10k, 1mV Overdrive ±15V ±13.0 ±13.6 V RL = 2k, 1mV Overdrive ±15V ±12.8 ±13.5 V RL = 10k, 1mV Overdrive ±5V ±3.0 ±3.7 V RL = 2k, 1mV Overdrive ±5V ±2.8 ±3.6 V IOUT Maximum Output Current VOUT = ±12.5V, 1mV Overdrive ±15V ±15 ±22 mA VOUT = ±2.5V, 1mV Overdrive ±5V ±15 ±22 mA ISC Output Short-Circuit Current VOUT = 0V, 0.2V Overdrive (Note 3) ±15V ±25 ±40 mA SR Slew Rate RL = 2k (Note 6) ±15V 20 30 V/μs ±5V 15 22 V/μs FPBW Full-Power Bandwidth 10V Peak, (Note 7) ±15V 475 kHz 3V Peak, (Note 7) ±5V 1160 kHz GBW Gain Bandwidth Product f = 100kHz, RL = 2k ±15V 140 200 MHz ±5V 130 190 MHz tS Settling Time 10V Step, 0.01%, AV = –1 ±15V 650 ns 10V Step, 150μV, AV = –1 ±15V 800 ns ROUT Output Resistance AV = –1, f = 100kHz ±15V 0.02 Ω Channel Separation VOUT = ±12.5V, RL = 2k ±15V 100 130 dB VOUT = ±2.5V, RL = 2k ±5V 100 130 dB IS Supply Current Per Amplifi er ±15V 4.1 5.2 mA ±5V 3.8 5 mA ΔVOS Input Offset Voltage Match ±15V 30 225 μV ±5V 50 350 μV ΔIB– Inverting Input Bias Current Match ±5V to ±15V 2 18 nA ΔIB+ Noninverting Input Bias Current Match ±5V to ±15V 5 78 nA ΔCMRR Common Mode Rejection Match VCM = ±12.5V (Note 9) ±15V 93 113 dB VCM = ±2.5V (Note 9) ±5V 93 115 dB ΔPSRR Power Supply Rejection Match VS = ±4.5V to ±15V (Note 9) 97 115 dB 14692f 3
