Datasheet LT1469-2 (Analog Devices) - 5
ОписаниеDual 200MHz, 30V/μs 16-Bit Accurate AV ≥ 2 Op Amp
Страниц / Страница12 / 5 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 201 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
26 предложений от 16 поставщиков
LT1469IS8-2#TRPBF
473 ₽
Зенер
Россия и страны ТС
LT1469IS8-2#PBF
от 655 ₽
LT1469IS8-2#PBF
от 1 493 ₽
Элитан
LT1469IS8-2
1 564 ₽
LT1469-2
l
denotes the specifi cations which apply over the full operating temperature range, –40°C ≤ TA ≤ 85°C, VCM = 0V unless otherwise noted. (Note 5) SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
VOS Input Offset Voltage S8 Package ±15V ● 500 μV ±5V ● 500 μV LT1469A, DF Package ±15V ● 300 μV ±5V ● 350 μV LT1469, DF Package ±15V ● 600 μV ±5V ● 600 μV ΔVOS/ΔT Input Offset Voltage Drift (Note 8) ±15V ● 1 6 μV/°C ±5V ● 1 5 μV/°C IOS Input Offset Current ±5V to ±15V ● ±120 nA ΔIOS/ΔT Input Offset Current Drift (Note 8) ±5V to ±15V ● 120 pA/°C IB– Inverting Input Bias Current ±5V to ±15V ● ±40 nA ΔIB–/ΔT Inverting Input Bias Current Drift (Note 8) ±5V to ±15V ● 80 pA/°C IB+ Noninverting Input Bias Current ±5V to ±15V ● ±80 nA VCM Input Voltage Range (Positive) Guaranteed by CMRR ±15V ● 12.5 V ±5V ● 2.5 V Input Voltage Range (Negative) Guaranteed by CMRR ±15V ● –12.5 V ±5V ● –2.5 V CMRR Common Mode Rejection Ratio VCM = ±12.5V ±15V ● 92 dB VCM = ±2.5V ±5V ● 92 ±4.5 dB Minimum Supply Voltage Guaranteed by PSRR ● V PSRR Power Supply Rejection Ratio VS = ±4.5V to ±15V ● 93 dB AVOL Large-Signal Voltage Gain VOUT = ±12,5V, RL = 10k ±15V ● 75 V/mV VOUT = ±12.5V, RL = 2k ±15V ● 75 V/mV VOUT = ±2.5V, RL = 10k ±5V ● 75 V/mV VOUT = ±2.5V, RL = 2k ±5V ● 75 V/mV VOUT Maximum Output Swing RL = 10k, 1mV Overdrive ±15V ● ±12.8 V RL = 2k, 1mV Overdrive ±15V ● ±12.6 V RL = 10k, 1mV Overdrive ±5V ● ±2.8 V RL = 2k, 1mV Overdrive ±5V ● ±2.6 V IOUT Maximum Output Current VOUT = ±12.5V, 1mV Overdrive ±15V ● ±7 mA VOUT = ±2.5V, 1mV Overdrive ±5V ● ±7 mA ISC Output Short-Circuit Current VOUT = 0V, 0.2V Overdrive (Note 3) ±15V ● ±12 mA SR Slew Rate RL = 2k (Note 6) ±15V ● 15 V/μs ±5V ● 11 V/μs GBW Gain Bandwidth Product f = 100kHz, RL = 2k ±15V ● 110 200 MHz ±5V ● 100 190 MHz Channel Separation VOUT = ±12.5V, RL = 2k ±15V ● 96 dB VOUT = ±2.5V, RL = 2k ±5V ● 96 dB IS Supply Current Per Amplifi er ±15V ● 7 mA ±5V ● 6.8 mA ΔVOS Input Offset Voltage Match ±15V ● 800 μV ±5V ● 800 μV ΔIB– Inverting Input Bias Current Match ±5V to ±15V ● 78 nA ΔIB+ Noninverting Input Bias Current ±5V to ±15V ● 158 nA Match ΔCMRR Common Mode Rejection Match VCM = ±12.5V (Note 9) ±15V ● 89 dB VCM = ±2.5V (Note 9) ±5V ● 89 dB ΔPSRR Power Supply Rejection Match VS = ±4.5V to ±15V (Note 9) ● 90 dB 14692f 5
