Datasheet LT6558 (Analog Devices) - 7
Описание550MHz, 2200V/µs Gain of 1, Single Supply Triple Video Amplifier with Input Bias Control
Страниц / Страница12 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Noise Spectral Density. …
Формат / Размер файлаPDF / 215 Кб
TYPICAL PERFORMANCE CHARACTERISTICS. Input Noise Spectral Density. Enable/Disable Response. Large-Signal Transient Response
TYPICAL PERFORMANCE CHARACTERISTICS Input Noise Spectral Density Enable/Disable Response Large-Signal Transient Response
IC AMP GENERAL PURPOSE 16SSOP. Video Amp, 3 General Purpose 16-SSOP. Linear - Amplifiers - Video Amps and Modules
LT6558IGN#TRPBF
235 ₽
LT6558IGN#TRPBF
257 ₽
Рутоника
LT6558IGN#TRPBF
305 ₽
LT6558IGN#TRPBF
LT6558
6 1000 1000 VS = 5V VEN(DISABLE) VIN = 2.5V INPUT CURRENT NOISE (pA/ 5 √Hz) VS = 5V +i 4 V n OUT = 2VP-P 100 100 RL = 150Ω 3 e V n OUT 2 VOLTAGE (V) 10 10 1 √Hz) INPUT VOLTAGE NOISE (nV/ 0 VEN(ENABLE) 1 0 –1 0.01 0.1 1 10 100 0 0.4 0.8 1.2 1.6 2.0 2.4 2.6 FREQUENCY (kHz) TIME (µs) 6558 G27 6558 G28
Large-Signal Transient Response Small-Signal Transient Response
5 2.65 VS = 5V VS = 5V VIN = 2VP-P VIN = 100mVP-P R R 4 L = 150Ω L = 150Ω 2.60 3 2.55 OUTPUT (V) 2 OUTPUT (V) 2.50 1 0 2.45 0 2 4 6 8 10 12 14 16 18 20 0 2 4 6 8 10 12 14 16 18 20 TIME (ns) TIME (ns) 6558 G29 6558 G30
PIN FUNCTIONS
E
N (Pin 1):
Enable Control Pin. The part is enabled when
IN G (Pin 5):
Green Channel Input. This pin has a nomi- this pin is pulled low. An internal pull-up resistor of 40k nal impedance of 450kΩ with input bias circuit inactive, will turn the part off if this pin is unconnected. Pin 16 open.
GND (Pin 2):
Ground Reference for Enable Pin (Pin 1)
GND G (Pin 6):
Ground of Green Channel Amplifi er. This and Bias Control Voltage Pin (Pin 16). This pin must be pin is not internally connected to other ground pins and connected externally to ground. must be connected externally to ground.
IN R (Pin 3):
Red Channel Input. This pin has a nominal
IN B (Pin 7):
Blue Channel Input. This pin has a nominal impedance of 450kΩ with input bias circuit inactive, impedance of 450kΩ with input bias circuit inactive, Pin 16 open. Pin 16 open.
GND R (Pin 4):
Ground of Red Channel Amplifi er. This pin
GND B (Pin 8):
Ground of Blue Channel Amplifi er. This is not internally connected to other ground pins and must pin is not internally connected to other ground pins and be connected externally to ground. must be connected externally to ground. 6558f 7
