Datasheet LT6205, LT6206, LT6207 (Analog Devices) - 4
ОписаниеQuad Single Supply 3V, 100MHz Video Op Amps
Страниц / Страница18 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes specifi cations which apply over …
Формат / Размер файлаPDF / 267 Кб
ELECTRICAL CHARACTERISTICS. The. denotes specifi cations which apply over the specifi ed temperature
ELECTRICAL CHARACTERISTICS The denotes specifi cations which apply over the specifi ed temperature
27 предложений от 14 поставщиков
Микросхема Видеоусилитель, OP Amp Single Volt Fdbk R-R O/P ‚±6.3V/12.6V Automotive 5Pin TSOT-23 T/R
LT6205HS5#TRMPBF
82 ₽
LT6205HS5#TRMPBF
от 396 ₽
ЗУМ-СМД
LT6205HS5#TRMPBF
LifeElectronics
LT6205HS5#TRMPBF
LT6205/LT6206/LT6207
l
denotes specifi cations which apply over the specifi ed temperature range, otherwise specifi cations are at TA = 25°C. VS = ±5V; VCM = VOUT = 0V, unless otherwise noted. LT6205C/LT6206C/LT6207C LT6205I/LT6206I/LT6207I SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 1 4.5 mV l 6 mV Input Offset Voltage Match 1 3 mV (Channel-to-Channel) (Note 5) l 4 mV Input Offset Voltage Drift (Note 6) l 10 18 μV/°C IB Input Bias Current l 18 30 μA IOS Input Offset Current l 0.6 3 μA Input Noise Voltage 0.1Hz to 10Hz 2 μVP-P en Input Noise Voltage Density f = 10kHz 9 nV/√Hz in Input Noise Current Density f = 10kHz 4 pA/√Hz Input Resistance VCM = –5V to 3V 1 MΩ Input Capacitance 2 pF CMRR Common Mode Rejection Ratio VCM = –5V to 3V l 78 90 dB Input Voltage Range l –5 3 V PSRR Power Supply Rejection Ratio VS = ±2V to ±6V l 67 75 dB AVOL Large-Signal Voltage Gain VO = –4V to 4V, RL = 1k l 50 133 V/mV VO = –3V to 3V, RL = 150Ω l 7.5 20 V/mV Output Voltage Swing No Load, Input Overdrive = 30mV l ±4.88 ±4.92 V IOUT = ±5mA l ±4.75 ±4.85 V IOUT = ±25mA l ±3.8 ±4.35 V ISC Short-Circuit Current Short to Ground ±40 ±60 mA l ±30 mA IS Supply Current per Amplifi er 4 5.6 mA l 6.5 mA GBW Gain Bandwidth Product f = 2MHz l 65 100 MHz SR Slew Rate AV = –1, RL = 1k 350 600 V/μs VO = –4V to 4V, Measured from –3V to 3V Channel Separation f = 10MHz 90 dB FPBW Full Power Bandwidth VOUT = 8VP-P (Note 8) 14 24 MHz ts Settling Time to 3% ΔVOUT = 2V, AV = –1, RL = 150Ω 15 ns Settling Time to 1% 25 ns Differential Gain AV = 2, RL = 150Ω, Output Black Level = 1V 0.05 % Differential Phase AV = 2, RL = 150Ω, Output Black Level = 1V 0.08 Deg
The
l
denotes specifi cations which apply over the full specifi ed temperature range, –40°C ≤ TA ≤ 125°C, otherwise specifi cations are at TA = 25°C. VS = 3V, 0V; VS = 5V, 0V; VCM = VOUT = 1V, unless otherwise noted. LT6205H SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 1 3.5 mV l 6 mV Input Offset Voltage Drift (Note 6) l 20 μV/°C IB Input Bias Current l 45 μA 620567fc 4 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION TYPICAL APPLICATION PACKAGE DESCRIPTION REVISION HISTORY TYPICAL APPLICATION RELATED PARTS
