Datasheet LT6552 (Analog Devices) - 6
Описание3.3V Single Supply Video Difference Amplifier
Страниц / Страница16 / 6 — 5V ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
Формат / Размер файлаPDF / 364 Кб
5V ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
5V ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the full operating
IC AMP DIFFERENTIAL 8DFN. Video Amp, 1 Differential 8-DFN (3x3). Linear - Amplifiers - Video Amps and Modules
LT6552IDD#TRPBF
127 ₽
Рутоника
LT6552IDD#TRPBF
162 ₽
LT6552IDD#TRPBF
176 ₽
LT6552IDD#TRPBF
LT6552 ±
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25
C. VS =
5V. Figure 2 shows the DC test circuit, VREF = VCM = 0V, VDIFF = 0V, VSHDN = V+, unless otherwise noted. RL = RF + RG = 1k. (Note 6) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
Shutdown Pin Current VSHDN = –4.5V ● 85 250 µA VSHDN = 4.7V ● 3 10 µA tON Turn-On Time VSHDN from – 4.5V to 4.7V 200 ns tOFF Turn-Off Time VSHDN from 4.7V to –4.5V 400 ns Shutdown Output Leakage Current VSHDN = –4.5V, V– ≤ VOUT ≤ V+ ● 0.25 µA
Note 1:
Absolute Maximum Ratings are those values beyond which the life
Note 6:
When RL = 1k is specified, the load resistor is RF + RG, but when of a device may be impaired. RL = 150Ω or RL = 75Ω is specified, then an additional resistor of that
Note 2:
The inputs are protected from ESD with diodes to the supplies. value is added to the output.
Note 3:
A heat sink may be required to keep the junction temperature
Note 7:
VOS measured at the output (Pin 6) is the contribution from both below absolute maximum. input pairs and is input referred.
Note 4:
The LT6552C/LT6552I are guaranteed functional over the
Note 8:
Minimum supply is guaranteed by the PSRR test. temperature range of –40°C to 85°C.
Note 9:
Full power bandwidth is calculated from the slew rate.
Note 5:
The LT6552C is guaranteed to meet specified performance from FPBW = SR/2πVp 0°C to 70°C and is designed, characterized and expected to meet specified
Note 10:
VS = 3.3V, tr and tf limits are guaranteed by correlation to performance from –40°C to 85°C, but is not tested or QA sampled at these VS = 5V and ±5V tests. temperatures. The LT6552I is guaranteed to meet specified performance from – 40°C to 85°C. RG RG 100Ω 100Ω 0.1% 0.1% REF FB REF FB 1µF R 1µF R –IN V+ F –IN V+ F 900Ω – 900Ω – VDIFF + VDIFF +IN OUT + 0.1% +IN OUT 0.1% V– SHDN V– SHDN VCM – + + + + + + V– + + VREF – – VCM VSHDN – – V+ RL – 1µF VSHDN – – V+ RL 6552 F01 6552 F02
Figure 1. 3.3V, 5V DC Test Circuit Figure 2.
5V DC Test Circuit
6552f 6
