Datasheet LT6202, LT6203, LT6204 (Analog Devices) - 9
ОписаниеQuad 100MHz, Rail-to-Rail Input and Output, Ultralow 1.9nV√Hz Noise, Low Power Op Amps
Страниц / Страница28 / 9 — ELECTRICAL CHARACTERISTICS TA = 25°C, VS =±5V; VCM = VOUT = 0V, unless …
ELECTRICAL CHARACTERISTICS TA = 25°C, VS =±5V; VCM = VOUT = 0V, unless otherwise noted. SYMBOL PARAMETER. CONDITIONS. MIN. TYP
ELECTRICAL CHARACTERISTICS TA = 25°C, VS =±5V; VCM = VOUT = 0V, unless otherwise noted SYMBOL PARAMETER CONDITIONS MIN TYP
40 предложений от 20 поставщиков
Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT6202CS8#PBF Operational Amplifier, Single, 1 Amplifier, 100MHz, 25V/µs, 2.5V to 12.6V, SOIC, 8Pins
Рутоника
LT6202CS8#TRPBF
147 ₽
LT6202CS8 PBF
LT6202CS8
727GS
LT6202CS8
LT6202/LT6203/LT6204
ELECTRICAL CHARACTERISTICS TA = 25°C, VS =±5V; VCM = VOUT = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
CMRR Common Mode Rejection Ratio VCM = V – to V+ 65 85 dB VCM = –2V to 2V 85 98 dB CMRR Match (Channel-to-Channel) (Note 5) VCM = –2V to 2V 85 120 dB PSRR Power Supply Rejection Ratio VS = ±1.25V to ±5V 60 74 dB PSRR Match (Channel-to-Channel) (Note 5) VS = ±1.25V to ±5V 70 100 dB VOL Output Voltage Swing LOW Saturation No Load 5 50 mV (Note 7) ISINK = 5mA 87 190 mV ISINK = 20mA 245 460 mV VOH Output Voltage Swing HIGH Saturation No Load 40 95 mV (Note 7) ISOURCE = 5mA 95 210 mV ISOURCE = 20mA 320 600 mV ISC Short-Circuit Current ±30 ±40 mA IS Supply Current per Amp 2.8 3.5 mA GBW Gain Bandwidth Product Frequency = 1MHz 70 100 MHz SR Slew Rate AV = –1, RL = 1k, VO = 4V 18 25 V/µs FPBW Full Power Bandwidth (Note 9) VOUT = 3VP-P 1.9 2.6 MHz tS Settling Time 0.1%, VSTEP = 2V, AV = –1, RL = 1k 78 ns dG Differential Gain (Note 10) AV = 2, RF = RG = 499Ω, RL = 2k 0.05 % dP Differential Phase (Note 10) AV = 2, RF = RG = 499Ω, RL = 2k 0.03 DEG
The
l
denotes the specifications which apply over 0°C < TA < 70°C temperature range. VS = ±5V; VCM = VOUT = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage LT6203, LT6204, LT6202S8 VCM = 0V l 1.6 2.8 mV VCM = V+ l 3.2 6.8 mV VCM = V– l 2.8 5.8 mV LT6202 SOT-23 VCM = 0V l 1.6 3.0 mV VCM = V+ l 3.2 7.3 mV VCM = V– l 2.8 6.3 mV VOS TC Input Offset Voltage Drift (Note 8) VCM = Half Supply l 7.5 24 µV/°C Input Offset Voltage Match VCM = 0V l 0.2 1.0 mV (Channel-to-Channel) (Note 5) VCM = V– to V+ l 0.5 2.2 mV IB Input Bias Current VCM = Half Supply l –7.0 –1.4 µA VCM = V+ l 1.8 3.6 µA VCM = V– l –10 –4.3 µA ∆IB IB Shift VCM = V– to V+ l 5.4 13 µA IB Match (Channel-to-Channel) (Note 5) l 0.15 0.7 µA IOS Input Offset Current VCM = Half Supply l 0.1 1 µA VCM = V+ l 0.2 1.2 µA VCM = V– l 0.4 1.4 µA AVOL Large Signal Gain VO = ±4.5V, RL = 1k l 70 120 V/mV VO = ±2V, RL = 100 l 10 18 V/mV CMRR Common Mode Rejection Ratio VCM = V – to V+ l 65 84 dB VCM = –2V to 2V l 83 95 dB CMRR Match (Channel-to-Channel) (Note 5) VCM = –2V to 2V l 83 110 dB 620234fd 9 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
