Datasheet LT1722, LT1723, LT1724 (Analog Devices) - 7
ОписаниеQuad 200MHz Low Noise Precision Op Amps
Страниц / Страница18 / 7 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 306 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the temperature range of
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the temperature range of
39 предложений от 16 поставщиков
LT1722CS5#TRMPBF
117 ₽
LT1722CS5#TRMPBF
от 318 ₽
Эиком
LT1722CS5#TRMPBF
от 345 ₽
ЗУМ-СМД
LT1722CS5#TRMPBF
LT1722/LT1723/LT1724
denotes the specifi cations which apply over the temperature range of –40°C ≤ TA ≤ 85°C. VS = 5V, VCM = 2.5V, RL to 2.5V, unless otherwise noted. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 6) l 1000 µV LT1722 SOT-23 and LT1723 MS8 l 1200 µV Input VOS Drift (Note 9) l 3 10 μV/°C IOS Input Offset Current l 400 nA IB Input Bias Current l 400 nA Input Voltage Range + l 3.5 V Input Voltage Range – l 1.5 V CMRR Common Mode Rejection Ratio VCM = 1.5V to 3.5V l 75 dB AVOL Large-Signal Voltage Gain VOUT = 1.5V to 3.5V, RL = 500Ω l 2 V/mV VOUT Output Swing+ RL = 500Ω, VIN = ±10mV l 3.5 V Output Swing– RL = 500Ω, VIN = ±10mV l 1.5 V IOUT Output Current VOUT = 3.5V or 1.5V, 30mV Overdrive l 8 mA ISC Short-Circuit Current VOUT = 2.5V, VIN = ±1V l 10 mA SR Slew Rate AV = –1, (Note 7) l 20 V/μs GBW Gain Bandwidth (Note 10) f = 200kHz l 90 MHz Channel Separation VOUT = 1.5V to 3.5V, RL = 500Ω l 80 dB IS Supply Current l 6.45 mA
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings designed, characterized and expected to meet specifi ed performance from may cause permanent damage to the device. Exposure to any Absolute –40°C to 85°C but are not tested or QA sampled at these temperatures. Maximum Rating condition for extended periods may affect device The LT1722I/LT1723I/LT1724I are guaranteed to meet specifi ed reliability and lifetime. performance from –40°C to 85°C.
Note 2:
The inputs are protected by back-to-back diodes. If the differential
Note 6:
Input offset voltage is pulse tested and is exclusive of warm-up input voltage exceeds 0.7V, the input current should be limited to less than drift. 10mA.
Note 7:
Slew rate is measured between ±2V on the output with ±3V input
Note 3:
A heat sink may be required to keep the junction temperature for ±5V supplies and ±1V on the output with ±1.5V input for single 5V below the absolute maximum rating when the output is shorted supply. (For 5V supply, the voltage levels are 2.5V referred.) indefi nitely.
Note 8:
Full power bandwidth is calculated from the slew rate:
Note 4:
The LT1722C/LT1722I, LT1723C/LT1723I, LT1724C/LT1724I are FPBW = SR/2πVP guaranteed functional over the operating temperature range of
Note 9 :
This parameter is not 100% tested. –40°C to 85°C.
Note 10 :
This parameter is guaranteed through correlation with slew rate.
Note 5:
The LT1722C/LT1723C/LT1724C are guaranteed to meet specifi ed performance from 0°C to 70°C. The LT1722C/LT1723C/LT1724C are 172234fb 7
