Datasheet LT1800 (Analog Devices) - 6
Описание80MHz, 25V/µs Low Power Rail-to-Rail Input and Output Precision Op Amp
Страниц / Страница18 / 6 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 285 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the temperature range of
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the temperature range of
30 предложений от 15 поставщиков
Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT1800CS5#TRMPBF Operational Amplifier, Single, 80MHz, 1 Amplifier, 25V/s, 2.3V to 12.6V, TSOT-23, 5Pins
LT1800CS5#TRMPBF
от 75 ₽
IC Home
LT1800CS5#TRMPBF
316 ₽
LT1800CS5#TRMPBF
338 ₽
LT1800CS5#TRMPBF
LT1800
l
denotes the specifi cations which apply over the temperature range of 0°C ≤ TA ≤ 70°C. VS = ±5V, VCM = 0V, VOUT = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
I – OS Input Offset Current VCM = VS + 1V l 25 300 nA V + CM = VS – 0.2V l 25 300 nA AVOL Large-Signal Voltage Gain VO = –4V to 4V, RL = 1k l 20 55 V/mV VO = –2V to 2V, RL = 100Ω l 2 5 V/mV CMRR Common Mode Rejection Ratio V – CM = VS to 3.5V l 82 105 dB Input Common Mode Range l V – + S VS V PSRR Power Supply Rejection Ratio V + – S = 2.5V to 10V, VS = 0V l 74 91 dB VOL Output Voltage Swing Low (Note 7) No Load l 17 70 mV ISINK = 5mA l 105 210 mV ISINK = 20mA l 250 575 mV VOH Output Voltage Swing High (Note 7) No Load l 25 90 mV ISOURCE = 5mA l 150 310 mV ISOURCE = 20mA l 600 1100 mV ISC Short-Circuit Current l 25 45 mA IS Supply Current per Amplifi er l 2.4 3.5 mA GBW Gain Bandwidth Product Frequency = 2MHz l 70 MHz SR Slew Rate AV = –1, RL = 1k, VO = ±4V, Measured at VO = ±2V l 20 V/μs
The
l
denotes the specifi cations which apply over the temperature range of –40°C ≤ TA ≤ 85°C. VS = ±5V, VCM = 0V, VOUT = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V – OS Input Offset Voltage VCM = VS l 350 900 μV V – CM = VS (SOT-23) l 500 2250 μV VCM = VS+ l 0.75 4.5 mV VCM = VS+ (SOT-23) l 1 5.5 mV ΔV – + OS Input Offset Shift VCM = VS to VS – 1.5V l 50 750 μV VOS TC Input Offset Voltage Drift (Note 8) l 1.5 5 μV/°C I – B Input Bias Current VCM = VS + 1V l 50 450 nA VCM = VS+ – 0.2V l 450 2000 nA I – OS Input Offset Current VCM = VS + 1V l 25 350 nA VCM = VS+ – 0.2V l 25 350 nA AVOL Large-Signal Voltage Gain VO = –4V to 4V, RL = 1k l 16 55 V/mV VO = –1V to 1V, RL = 100Ω l 2 5 V/mV CMRR Common Mode Rejection Ratio V – CM = VS to 3.5V l 81 104 dB Input Common Mode Range l V – + S VS V PSRR Power Supply Rejection Ratio V + – S = 2.5V to 10V, VS = 0V l 73 90 dB VOL Output Voltage Swing Low (Note 7) No Load l 15 80 mV ISINK = 5mA l 105 220 mV ISINK = 10mA l 170 400 mV VOH Output Voltage Swing High (Note 7) No Load l 25 100 mV ISOURCE = 5mA l 150 350 mV ISOURCE = 10mA l 300 700 mV ISC Short-Circuit Current l 12.5 30 mA IS Supply Current per Amplifi er l 2.6 4 mA GBW Gain Bandwidth Product Frequency = 2MHz l 65 MHz SR Slew Rate AV = –1, RL = 1k, VO = ±4V, Measured at VO = ±2V l 15 V/μs 1800fa 6
