Datasheet LT1812 (Analog Devices) - 7
Описание | 3mA, 100MHz, 750V/µs Operational Amplifier with Shutdown |
Страниц / Страница | 16 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Common Mode Range. Input Bias … |
Формат / Размер файла | PDF / 251 Кб |
Язык документа | английский |
TYPICAL PERFORMANCE CHARACTERISTICS. Input Common Mode Range. Input Bias Current. Supply Current vs Temperature
LT1812
TYPICAL PERFORMANCE CHARACTERISTICS Input Common Mode Range Input Bias Current Supply Current vs Temperature vs Supply Voltage vs Common Mode Voltage
5 V+ 0 TA = 25°C –0.5 VS = ±5V 4 –1.0 –0.5 VS = ±5V –1.5 3 –2.0 V T S = ±2.5V A = 25°C –1.0 VOS < 1mV 2 2.0 1.5 SUPPLY CURRENT (mA) INPUT BIAS CURRENT (μA) –1.5 1 1.0 INPUT COMMON MODE RANGE (V) 0.5 0 V– –2.0 –50 –25 0 25 50 75 100 125 0 1 2 3 4 5 6 7 –5.0 –2.5 0 2.5 5.0 TEMPERATURE (°C) SUPPLY VOLTAGE (±V) INPUT COMMON MODE VOLTAGE (V) 1812 G01 1812 G02 1812 G03
Input Bias Current Open-Loop Gain vs Temperature Input Noise Spectral Density vs Resistive Load
0 100 10 75.0 TA = 25°C TA = 25°C V –0.2 S = ±5V INPUT CURRENT NOISE (pA/√ ) AV = 101 Hz 72.5 RS = 10k –0.4 70.0 V –0.6 i S = ±5V n 10 1 67.5 –0.8 e V n S = ±5V VS = ±2.5V 65.0 –1.0 OPEN-LOOP GAIN (dB) INPUT BIAS CURRENT (μA) VS = ±2.5V Hz ) –1.2 INPUT VOLTAGE NOISE (nV/√ 62.5 –1.4 1 0.1 60 –50 –25 0 25 50 75 100 125 10 100 1k 10k 100k 100 1k 10k TEMPERATURE (°C) FREQUENCY (Hz) LOAD RESISTANCE (Ω) 1812 G04 1812 G05 1812 G06
Output Voltage Swing Output Voltage Swing Open-Loop Gain vs Temperature vs Supply Voltage vs Load Current
75.0 V+ V+ VS = ±5V TA = 25°C VS = ±5V V –0.5 O = ±3V VIN = 30mV –0.5 V R IN = 30mV 72.5 L = 500Ω 85°C –1.0 –1.0 25°C R –1.5 R –1.5 –40°C 70.0 L = 500Ω L = 100Ω –2.0 –2.0 67.5 RL = 100Ω 2.0 2.0 65.0 R OPEN-LOOP GAIN (dB) 1.5 L = 100Ω 1.5 OUTPUT VOLTAGE SWING (V) 1.0 OUTPUT VOLTAGE SWING (V) 1.0 62.5 R 0.5 L = 500Ω 0.5 60.0 V– V– –50 –25 0 25 50 75 100 125 0 1 2 3 4 5 6 7 –60 –40 –20 0 20 40 60 TEMPERATURE (°C) SUPPLY VOLTAGE (±V) OUTPUT CURRENT (mA) 1812 G07 1812 G08 1812 G09 1812fb 7
