Datasheet LT1468 (Analog Devices) - 3
Описание90MHz, 22V/us 16-Bit Accurate Operational Amplifier
Страниц / Страница16 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 228 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
37 предложений от 20 поставщиков
Эиком
LT1468ACDD#PBF
от 1 244 ₽
LT1468ACDD-2-PBF
МосЧип
LT1468ACDD-2#PBF
ТаймЧипс
LT1468ACDD-PBF
LT1468
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
VOS Input Offset Voltage N8, S8 ±15V 30 75 μV ± 5V 50 175 μV LT1468A, DD Package ±15V 30 75 μV ± 5V 50 175 μV LT1468, DD Package ±15V 100 200 μV ± 5V 150 300 μV IOS Input Offset Current ±5V to ±15V 13 50 nA I – B Inverting Input Bias Current ±5V to ±15V 3 ±10 nA I + B Noninverting Input Bias Current ±5V to ±15V –10 ±40 nA Input Noise Voltage 0.1Hz to 10Hz ±5V to ±15V 0.3 μVP-P en Input Noise Voltage f = 10kHz ±5V to ±15V 5 nV/√Hz in Input Noise Voltage f = 10kHz ±5V to ±15V 0.6 pA/√Hz RIN Input Resistance VCM = ±12.5V ±15V 100 240 MΩ Differential ±15V 50 150 kΩ CIN Input Capacitance ±15V 4 pF Input Voltage Range + ±15V 12.5 13.5 V ±5V 2.5 3.5 V Input Voltage Range – ±15V –14.3 –12.5 V ±5V –4.3 –2.5 V CMRR Common Mode Rejection Ratio VCM = ±12.5V ±15V 96 110 dB VCM = ±2.5V ±5V 96 112 dB PSRR Power Supply Rejection Ratio VS = ±4.5V to ±15V 100 112 dB AVOL Large-Signal Voltage Gain VOUT = ±12.5V, RL = 10k ±15V 1000 9000 V/mV VOUT = ±12.5V, RL = 2k ±15V 500 5000 V/mV VOUT = ±2.5V, RL = 10k ±5V 1000 6000 V/mV VOUT = ±2.5V, RL = 2k ±5V 500 3000 V/mV VOUT Output Swing RL = 10k ±15V ±13.0 ±13.6 V RL = 2k ±15V ±12.8 ±13.5 V RL = 10k ± 5V ±3.0 ±3.6 V RL = 2k ±5V ±2.8 ±3.5 V IOUT Output Current VOUT = ±12.5V ±15V ±15 ±22 mA VOUT = ±2.5V ±5V ±15 ±22 mA ISC Short-Circuit Current VOUT = 0V, VIN = ±0.2V ±15V ±25 ±40 mA SR Slew Rate AV = –1, RL = 2k (Note 5) ±15V 15 22 V/μs ± 5V 11 17 V/μs Full-Power Bandwidth 10V Peak, (Note 6) ±15V 350 kHz 3V Peak, (Note 6) ±5V 900 kHz GBW Gain Bandwidth f = 100kHz, RL = 2k ±15V 60 90 MHz ±5V 55 88 MHz THD Total Harmonic Distortion AV = 2, VO = 10VP-P, f = 1kHz ±15V 0.00007 % AV = 2, VO = 10VP-P, f = 100kHz ±15V 0.0015 % tr, tf Rise Time, Fall Time AV = 1, 10% to 90%, 0.1V ±15V 11 ns ±5V 12 ns Overshoot AV = 1, 0.1V ±15V 30 % ±5V 35 % Propagation Delay AV = 1, 50% VIN to 50% VOUT, ±15V 9 ns 0.1V ±5V 10 ns 1468fb 3
