Datasheet LT1363 (Analog Devices) - 12
Описание70MHz, 1000V/µs Op Amp
Страниц / Страница12 / 12 — TYPICAL APPLICATIONS. Two Op Amp Instrumentation Amplifier. 2MHz, 4th …
Формат / Размер файлаPDF / 220 Кб
TYPICAL APPLICATIONS. Two Op Amp Instrumentation Amplifier. 2MHz, 4th Order Butterworth Filter
TYPICAL APPLICATIONS Two Op Amp Instrumentation Amplifier 2MHz, 4th Order Butterworth Filter
35 предложений от 16 поставщиков
Микросхема: IC VOLTAGE FEEDBACK 1 CIRC 8DIP
727GS
LT1363CN8#PBF
от 221 ₽
IC Home
LT1363CN8#PBF
522 ₽
ЗУМ-СМД
LT1363CN8
LT1363CN8#PBF
LT1363
U TYPICAL APPLICATIONS Two Op Amp Instrumentation Amplifier 2MHz, 4th Order Butterworth Filter
R5 R4 464 220 10k Ω 549Ω Ω R1 R2 47pF 10k 1k 22pF 464Ω 1.33k R3 VIN – – 549Ω 1.13k 1k 220pF LT1363 LT1363 – – + 470pF LT1363 V – + LT1363 V OUT OUT V + IN + + 1363 TA04    4  1 2 3 ( 2 3) R     R R  R + R GAIN =   1+    +  +  = 102 R3  2 R1 R4 R       5    TRIM R5 FOR GAIN TRIM R1 FOR COMMON-MODE REJECTION 1363 TA03 BW = 700kHz
U PACKAGE DESCRIPTION Dimension in inches (millimeters) unless otherwise noted. S8 Package 8-Lead Plastic Small Outline (Narrow 0.150)
(LTC DWG # 05-08-1610) 0.189 – 0.197* (4.801 – 5.004) 0.010 – 0.020 × 45° 0.053 – 0.069 8 7 6 5 (0.254 – 0.508) (1.346 – 1.752) 0.004 – 0.010 0.008 – 0.010 0 (0.101 – 0.254) (0.203 – 0.254) °– 8° TYP 0.228 – 0.244 0.150 – 0.157** 0.016 – 0.050 (5.791 – 6.197) (3.810 – 3.988) 0.014 – 0.019 0.050 (0.406 – 1.270) (0.355 – 0.483) (1.270) TYP BSC *DIMENSION DOES NOT INCLUDE MOLD FLASH. MOLD FLASH SHALL NOT EXCEED 0.006" (0.152mm) PER SIDE **DIMENSION DOES NOT INCLUDE INTERLEAD FLASH. INTERLEAD 1 2 3 4 FLASH SHALL NOT EXCEED 0.010" (0.254mm) PER SIDE SO8 1298
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LT1364/LT1365 Dual and Quad 70MHz, 1000V/µs Op Amps Dual and Quad Versions of LT1363 LT1360 50MHz, 800V/µs Op Amp Lower Power Version of LT1363, VOS = 1mV, IS = 4mA LT1357 25MHz, 600V/µs Op Amp Lower Power Version of LT1363, VOS = 0.6mV, IS = 2mA LT1812 100MHz, 750V/µs Op Amp Low Voltage, Low Power LT1363, VOS = 1.5mV, IS = 3mA 1363fa LT/TP 0400 2K REV A • PRINTED IN USA 12 Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear-tech.com LINEAR TECHNOLOGY CORPORATION 1994
