Datasheet LT1997-3 (Analog Devices) - 6
ОписаниеPrecision, Wide Voltage Range Gain Selectable Amplifier
Страниц / Страница38 / 6 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
ВерсияA
Формат / Размер файлаPDF / 3.3 Мб
7 предложений от 7 поставщиков
IC OPAMP GP 1 CIRCUIT 14DFN. General Purpose Amplifier 1 Circuit Rail-to-Rail 14-DFN (4x4). Linear - Amplifiers - Instrumentation, OP Amps,...
LT1997HDF-3#TRPBF
20 ₽
LT1997HDF-3#TRPBF
455 ₽
LT1997HDF-3#TRPBF
523 ₽
LT1997HDF-3#TRPBF
link to page 15 link to page 25 link to page 25 link to page 15 LT1997-3
l
denotes the specifications which apply over the full operating temperature range, –40°C < TA < 85°C for I-grade parts, –40°C < TA < 125°C for H-grade parts, otherwise specifications are at TA = 25°C. Difference Amplifier Configuration, V+ = 5V, V– = 0V, VCM = VOUT = VREF = VREF1 = VREF2 = Mid-Supply. VCMOP is the common mode voltage of the internal op amp. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
Input Referred Noise Voltage f = 0.1Hz to 10Hz G = 1 1.4 µVP-P G = 3 1 µVP-P G = 9 0.8 µVP-P VOL Output Voltage Swing Low (Referred to V–) No Load l 15 50 mV ISINK = 5mA l 280 500 mV VOH Output Voltage Swing High (Referred to V+) No Load l 15 50 mV ISOURCE = 5mA l 450 800 mV ISC Short-Circuit Output Current 50Ω to V+ l 10 27 mA 50Ω to V– l 10 25 mA SR Slew Rate ∆VOUT = 3V l 0.45 0.75 V/µs BW Small signal –3dB Bandwidth G = 1 1100 kHz G = 3 700 kHz G = 9 300 kHz tS Settling Time G = 1 0.1%, ∆VOUT = 2V 5.4 µs 0.01%, ∆VOUT = 2V 91 µs G = 3 0.1%, ∆VOUT = 2V 6 µs 0.01%, ∆VOUT = 2V 21 µs G = 9 0.1%, ∆VOUT = 2V 7 µs 0.01%, ∆VOUT = 2V 36 µs VS Supply Voltage 3 50 V l 3.3 50 V tON Turn-On Time 22 µs VIL SHDN Input Logic Low (Referred to V+) l –2.5 V VIH SHDN Input Logic High (Referred to V+) l –1.2 V ISHDN SHDN Pin Current l –10 –15 µA IS Supply Current Active, VSHDN ≥ V+ – 1.2V 330 370 µA Active, VSHDN ≥ V+ –1.2V l 525 µA Shutdown, VSHDN ≤ V+ – 2.5V 15 20 µA Shutdown, VSHDN ≤ V+ – 2.5V l 40 µA
Note 1:
Note 6:
This parameter is not 100% tested. may cause permanent damage to the device. Exposure to any Absolute
Note 7:
Input voltage range is guaranteed by design and through Maximum Rating condition for extended periods may affect device correlation with the ±15V CMRR test. The Input Voltage Range numbers reliability and lifetime. specified in the table guarantee that the internal op amp operates in its
Note 2:
See “Common Mode Voltage Range” and “High Common Mode normal operating region. The Input voltage range can be significantly Voltage Difference Amplifiers” in the Applications Information section of higher if the internal op amp operates in its Over-The-Top® operating this data sheet for other considerations when taking +INA/–INA pins to region. See “Common Mode Voltage Range” in the Applications ±160V and +INB/–INB/+INC/–INC pins to +80V. Information section to determine the valid input voltage range under
Note 3:
A heat sink may be required to keep the junction temperature various operating conditions. below absolute maximum. This depends on the power supply, input
Note 8:
Input impedance is tested by a combination of direct voltages and the output current. measurements and correlation to the CMRR and gain error tests.
Note 4:
The LT1997I-3 is guaranteed functional over the operating
Note 9:
Offset voltage, offset voltage drift and PSRR are defined as temperature range of –40°C to 85°C. The LT1997H-3 is guaranteed referred to the internal op amp. You can calculate output offset as follows. functional over the operating temperature range of –40°C to 125°C. In the case of balanced source resistance, VOS,OUT = (VOS • NOISEGAIN)
Note 5:
The LT1997I-3 is guaranteed to meet specified performance + (IOS • 22.5k) + (IB • 22.5k • (1– RP/RN)) where RP and RN are the total from –40°C to 85°C. The LT1997H-3 is guaranteed to meet specified resistance at the op amp positive and negative terminal, respectively. performance from –40°C to 125°C. Rev A 6 For more information www.analog.com Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS PIN FUNCTIONS BLOCK DIAGRAM APPLICATIONS INFORMATION TYPICAL APPLICATIONS PACKAGE DESCRIPTION REVISION HISTORY TYPICAL APPLICATION RELATED PARTS
