Datasheet LT6375 (Analog Devices) - 2
Описание±270V Common Mode Voltage Difference Amplifier
Страниц / Страница32 / 2 — ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION …
ABSOLUTE MAXIMUM RATINGS. (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING*
21 предложений от 12 поставщиков
LT6375HDF#TRPBF
161 ₽
LT6375HDF#PBF
243 ₽
LT6375HDF#TRPBF
412 ₽
LT6375HDF#TRPBF
LT6375
Supply Voltages Output Short-Circuit Duration (Note 3) Thermally Limited (V+ to V–) ..60V Temperature Range (Notes 4, 5) +IN, –IN, (Note 2) LT6375I..–40°C to 85°C Each Input ...±270V LT6375H .. –40°C to 125°C Differential ..±540V Storage Temperature Range .. –65°C to 150°C +REFA, –REFA, +REFB, –REFB, +REFC, –REFC, MSOP Lead Temperature (Soldering, 10 sec) ..300°C REF, SHDN (Note 2) .. (V+ + 0.3V) to (V– –0.3V) Output Current (Continuous) (Note 6) ..50mA
PIN CONFIGURATION
TOP VIEW +IN 1 14 –IN TOP VIEW +IN 1 16 –IN +REFA 3 12 –REFA +REFA 3 14 –REFA +REFB 4 15 V– 11 –REFB +REFB 5 12 –REFB +REFC 6 11 –REFC +REFC 5 10 –REFC REF 7 10 V+ REF 6 9 V+ V– 8 9 OUT SHDN 7 8 OUT MS PACKAGE VARIATION: MS16 (12) 16-LEAD PLASTIC MSOP T DF PACKAGE JMAX = 150°C, θJA = 130°C/W 14(12)-LEAD (4mm × 4mm) PLASTIC DFN TJMAX = 150°C, θJA = 43°C/W, θJC = 4°C/W EXPOSED PAD (PIN 15) IS V–, MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LT6375IDF#PBF LT6375IDF#TRPBF 6375 14-Lead (4mm × 4mm) Plastic DFN –40°C to 85°C LT6375HDF#PBF LT6375HDF#TRPBF 6375 14-Lead (4mm × 4mm) Plastic DFN –40°C to 125°C LT6375AHDF#PBF LT6375AHDF#TRPBF 6375 14-Lead (4mm × 4mm) Plastic DFN –40°C to 125°C LT6375IMS#PBF LT6375IMS#TRPBF 6375 16-Lead Plastic MSOP –40°C to 85°C LT6375HMS#PBF LT6375HMS#TRPBF 6375 16-Lead Plastic MSOP –40°C to 125°C LT6375AHMS#PBF LT6375AHMS#TRPBF 6375 16-Lead Plastic MSOP –40°C to 125°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. 6375fa 2 For more information www.linear.com/LT6375 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Package Description Revision History Typical Application Related Parts
