Datasheet LT6000, LT6001, LT6002 (Analog Devices) - 7
ОписаниеSingle, Dual and Quad, 1.8V, 13µA Precision Rail-to-Rail Op Amps
Страниц / Страница20 / 7 — TYPICAL PERFOR A CE CHARACTERISTICS. TC V. Supply Current vs Supply …
Формат / Размер файлаPDF / 325 Кб
TYPICAL PERFOR A CE CHARACTERISTICS. TC V. Supply Current vs Supply Voltage. OS Distribution. Change in Input Offset Voltage
TYPICAL PERFOR A CE CHARACTERISTICS TC V Supply Current vs Supply Voltage OS Distribution Change in Input Offset Voltage
IC OPAMP GP 2 CIRCUIT 10DFN. General Purpose Amplifier 2 Circuit Rail-to-Rail 10-DFN (3x3). Linear - Amplifiers - Instrumentation, OP Amps,...
LT6001CDD#TRPBF
102 ₽
LT6001CDD#TRPBF
151 ₽
LT6001CDD#TRPBF
178 ₽
LT6001CDD#TRPBF
LT6000/LT6001/LT6002
W U TYPICAL PERFOR A CE CHARACTERISTICS V TC V Supply Current vs Supply Voltage OS Distribution OS Distribution
30 20 35 VS = 5V, 0V VS = 5V, 0V VCM = 0.5V VCM = 2.5V 18 VCM = 2.5V µA) 30 25 MS8 PACKAGE MS8, GN16, 16 TA = 125°C DD10 PACKAGES 14 –40°C TO 85°C 25 20 12 20 15 T 10 A = 25°C 15 8 10 6 10 PERCENT OF UNITS (%) PERCENT OF UNITS (%) 4 TA = –55°C 5 5 2 SUPPLY CURRENT PER AMPLIFIER ( 0 0 0 –600 –400 –200 0 200 400 600 –5 –4 –3 –2 –1 0 1 2 3 4 5 0 2 4 6 8 10 12 14 16 18 INPUT OFFSET VOLTAGE (µV) DISTRIBUTION (µV/°C) TOTAL SUPPLY VOLTAGE (V) 60012 G01 20012 G02 600012 G03
Change in Input Offset Voltage Input Offset Voltage Input Offset Voltage vs Total Supply Voltage vs Total Supply Voltage vs Input Common Mode Voltage
300 400 400 V V CM = 0.5V CM = 0.5V VS = 5V, 0V TYPICAL PART TYPICAL PART 250 300 300 µV) 200 µV) 200 TA = 125°C µV) 200 150 100 TA = 125°C TA = 25°C 100 T 100 A = 25°C T 0 T A = 125°C A = 25°C 50 0 OFFSET VOLTAGE ( –100 OFFSET VOLTAGE ( 0 T TA = –55°C A = –55°C –100 CHANGE IN OFFSET VOLTAGE ( –100 TA = –55°C –50 –100 –300 –200 1 1.5 2 2.5 3 0 2 4 6 8 10 12 14 16 18 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 TOTAL SUPPLY VOLTAGE (V) TOTAL SUPPLY VOLTAGE (V) INPUT COMMON MODE VOLTAGE (V) 60012 G35 600012 G05 60012 G06
Input Bias Current Output Saturation Voltage Output Saturation Voltage vs Common Mode Voltage vs Load Current (Output High) vs Load Current (Output Low)
12.5 1.0 1.0 VS = 5V, 0V VS = 5V, 0V VS = 5V, 0V INPUT OVERDRIVE = 30mV INPUT OVERDRIVE = 30mV 10.0 7.5 T T T A = 25°C A = 25°C A = 125°C 5.0 TA = 125°C TA = 125°C 0.1 0.1 2.5 TA = –55°C TA = –55°C TA = 25°C 0 TA = –55°C INPUT BIAS CURRENT (nA) –2.5 OUTPUT HIGH SATURATION VOLTAGE (V) OUTPUT LOW SATURATION VOLTAGE (V) –5.0 0.01 0.01 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 0.001 0.01 0.1 1 10 0.001 0.01 0.1 1 10 COMMON MODE VOLTAGE (V) SOURCING LOAD CURRENT (mA) SINKING LOAD CURRENT (mA) 60012 G07 60012 G08 60012 G08 600012fa 7
