Datasheet LT1880 (Analog Devices) - 3
ОписаниеSOT-23, Rail-to-Rail Output, Picoamp Input Current Precision Op Amp
Страниц / Страница12 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 233 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
IC OPAMP GP 1 CIRCUIT TSOT23-5. General Purpose Amplifier 1 Circuit Rail-to-Rail TSOT-23-5. Linear - Amplifiers - Instrumentation, OP Amps, Buffer...
LT1880IS5#TRPBF
180 ₽
LT1880IS5#TRPBF
207 ₽
ЧипСити
LT1880IS5#TRPBF
207 ₽
SUV System
LT1880IS5#TRPBF
LT1880
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VS = 5V, 0V; VCM = 2.5V unless otherwise noted. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
CMRR Common Mode Rejection Ratio 1V < VCM < 3.8V l 116 135 dB PSRR Power Supply Rejection Ratio V– = 0V, VCM = 1.5V; 2.7V < V+ < 32V l 110 135 dB Minimum Operating Supply Voltage l 2.4 2.7 V AVOL Large Signal Voltage Gain RL = 10k; 1V < VOUT < 4V 500 1600 V/mV l 400 V/mV RL = 2k; 1V < VOUT < 4V 400 800 V/mV l 300 V/mV RL = 1k; 1V < VOUT < 4V 300 400 V/mV l 250 V/mV VOL Output Voltage Swing Low No Load l 20 55 mV ISINK = 100μA l 35 65 mV ISINK = 1mA l 130 200 mV VOH Output Voltage Swing High V+ = 5V; No Load l 130 250 mV (Referred to V+) V+ = 5V; ISOURCE = 100μA l 150 270 mV V+ = 5V; ISOURCE = 1mA l 220 380 mV IS Supply Current per Amplifi er V+ = 3V 1.2 1.8 mA l 2.2 mA V+ = 5V 1.2 1.9 mA l 2.3 mA V+ = 12V 1.35 2 mA l 2.4 mA ISC Short-Circuit Current VOUT Short to GND l 10 18 mA VOUT Short to V+ l 10 20 mA GBW Gain-Bandwidth Product f = 20kHz 0.8 1.1 MHz tS Settling Time 0.01%, VOUT = 1.5V to 3.5V 10 μs AV = –1, RL = 2k FPBW Full Power Bandwidth (Note 7) VOUT = 4VP-P 32 kHz THD Total Harmonic Distortion and Noise VO = 2VP-P, AV = –1, f = 1kHz, Rf = 1k, BW = 22kHz 0.002 % VO = 2VP-P, AV = 1, f = 1kHz, RL = 10k, BW = 22kHz 0.0008 % SR+ Slew Rate Positive AV = –1 0.25 0.4 V/μs l 0.2 V/μs SR– Slew Rate Negative AV = –1 0.25 0.55 V/μs l 0.25 V/μs
The
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VS= ±15V, VCM = 0V unless otherwise noted. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 40 150 μV 0°C < T l A < 70°C 200 μV –40°C < T l 250 μV A < 85°C Input Offset Voltage Drift 0°C < TA < 70°C l 0.3 1.2 μV/°C (Note 6) –40°C < T l A < 85°C 0.3 1.2 μV/°C IOS Input Offset Current 150 900 pA 0°C < T l A < 70°C 1200 pA –40°C < T l 1400 pA A < 85°C IB Input Bias Current 150 900 pA 0°C < T l A < 70°C 1200 pA –40°C < T l 1500 pA A < 85°C Input Noise Voltage 0.1Hz to 10Hz 0.5 μV/p-p 1880fa 3
