Datasheet LT1784 (Analog Devices) - 4
Описание2.5MHz, Over-The-Top Low Power, Rail-to-Rail Input and Output Op Amp in SOT-23
Страниц / Страница12 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 204 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the specifi ed
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the specifi ed
IC OPAMP GP 1 CIRCUIT TSOT23-6. General Purpose Amplifier 1 Circuit Rail-to-Rail TSOT-23-6. Linear - Amplifiers - Instrumentation, OP Amps, Buffer...
LT1784IS6#TRPBF
59 ₽
LT1784IS6#TRPBF
95 ₽
Рутоника
LT1784IS6#TRPBF
136 ₽
LT1784IS6#TRPBF
LT1784
l
denotes the specifi cations which apply over the specifi ed temperature range, otherwise specifi cations are at TA = 25°C. VS = 3V, 0V; VS = 5V, 0V, VCM = VOUT = half supply, for the 6-lead part VPIN5 = 0V, pulse power tested unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
GBW Gain Bandwidth Product f = 5kHz 1.5 2.5 MHz (Note 4) 0°C ≤ TA ≤ 70°C l 1.2 MHz –40°C ≤ TA ≤ 85°C l 1.1 MHz SR Slew Rate AV = –1, RL = ∞ 1.2 2.1 V/μs (Note 5) 0°C ≤ T l A ≤ 70°C 1.1 V/μs –40°C ≤ T l A ≤ 85°C 1.0 V/μs FPBW Full-Power Bandwidth (Note 9) VOUT = 2VP-P 350 kHz tS Settling Time VS = 5V, ΔVOUT = 2V to 0.1%, AV = –1 3.7 μs THD Distortion VS = 3V, VO = 1.8VP-P , AV = 1, RL = 10k, f = 1kHz 0.001 %
The
l
denotes the specifi cations which apply over the specifi ed temperature range, otherwise specifi cations are at TA = 25°C. VS = ±5V, VCM = 0V, VOUT = 0V, for the 6-lead part VPIN5 = V–, pulse power tested unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage TA = 25°C 1.6 3.75 mV 0°C ≤ TA ≤ 70°C l 4.50 mV –40°C ≤ TA ≤ 85°C l 4.80 mV ΔVOS/ΔT Input Offset Voltage Drift (Note 7) –40°C ≤ TA ≤ 85°C l 5 15 μV/°C IOS Input Offset Current l 25 50 nA IB Input Bias Current l 250 500 nA ΔIB/ΔT Input Bias Current Drift 0°C ≤ TA ≤ 70°C l 0.4 nA/°C Input Noise Voltage 0.1Hz to 10Hz 1.5 μVP-P en Input Noise Voltage Density f = 1kHz 25 nV/√Hz in Input Noise Current Density f = 1kHz 0.3 pA/√Hz RIN Input Resistance Differential l 100 200 kΩ Common Mode, VCM = –5V to 13V l 45 80 kΩ CIN Input Capacitance 5 pF VCM Input Voltage Range l –5 13 V CMRR Common Mode Rejection Ratio VCM = –5V to 13V l 60 70 dB AVOL Large-Signal Voltage Gain VO = ±4V, RL = 10k 50 100 V/mV 0°C ≤ TA ≤ 70°C l 35 V/mV VOL Output Voltage Swing LOW No Load l –4.996 –4.99 V ISINK = 5mA l –4.800 –4.60 V ISINK = 10mA l –4.650 –4.40 V VOH Output Voltage Swing HIGH No Load l 4.885 4.92 V ISOURCE = 5mA l 4.550 4.75 V ISOURCE = 10mA l 4.400 4.65 V ISC Short-Circuit Current (Note 2) Short to GND 15 27 mA 0°C ≤ TA ≤ 70°C l 10 mA PSRR Power Supply Rejection Ratio VS = ±1.5V to ±9V l 90 100 dB IS Supply Current 540 800 μA l 975 μA Supply Current, Shutdown VPIN5 = –3V, VS = ±5V, No Load (Note 8) l 8 20 μA ISHDN SHDN Pin Current VPIN5 = –4.7V (On), VS = ±5V, No Load (Note 8) l 0.5 nA VPIN5 = –3V (Shutdown), VS = ±5V, No Load (Note 8) l 2.0 8 μA Maximum SHDN Pin Current VPIN5 = 9V, VS = ±9V (Note 8) l 10 30 μA Output Leakage Current, Shutdown VPIN5 = –7V, VS = ±9V, No Load (Note 8) l 0.05 1 μA 1784fa 4
