Линейка продуктов KEEN SIDE
Datasheet LT1783 (Analog Devices) - 6
Описание1.25MHz, Over-The-Top Micropower, Rail-to-Rail Input and Output Op Amp in SOT-23
Страниц / Страница16 / 6 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 183 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
38 предложений от 22 поставщиков
Микросхема Буферный усилитель, IC OPAMP GP 1.3MHz RRO TSOT23-5
LT1783CS5#TRPBF
от 43 ₽
Элитан
LT1783CS5
338 ₽
LT1783CS5-TRPBFREE
LifeElectronics
LT1783CS5#TR#PBF
LT1783
l
denotes the specifi cations which apply over the full operating temperature range of –40°C ≤ TA ≤ 125°C. VS = 3V, 0V; VS = 5V, 0V; VCM = VOUT = half supply, for the 6-lead part VPIN5 = 0V, pulse power tested unless otherwise specifi ed. (Note 4) LT1783H SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
Minimum Supply Voltage l 2.7 V Reverse Supply Voltage IS = –100μA l 18 V IS Supply Current 210 300 μA l 600 μA Supply Current, SHDN VPIN5 = 2V, No Load (Note 10) l 25 μA ISHDN Shutdown Pin Current VPIN5 = 0.3V, No Load (Note 10) l 0.5 nA VPIN5 = 2V, No Load (Note 10) l 12 μA Output Leakage Current VPIN5 = 2V, No Load (Note 10) l 2.5 μA Maximum Shutdown Pin Current VPIN5 = 18V, No Load (Note 10) l 40 μA GBW Gain Bandwidth Product f = 5kHz (Note 5) 750 1250 kHz l 400 kHz SR Slew Rate AV = –1, RL = ∞ (Note 7) 0.24 0.42 V/μs l 0.12 V/μs
The
l
denotes the specifi cations which apply over the full operating temperature range of –40°C ≤ TA ≤ 125°C. VS = ±5V, VCM = 0V, VOUT = 0V, VSHDN = V–, TA = –40°C to 125°C, for the 6-lead part VPIN5 = V–, pulse power tested unless otherwise specifi ed. (Note 4) LT1783H SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 500 950 μV l 3.1 mV Input Offset Voltage Drift (Note 9) l 15 μV/°C IOS Input Offset Current l 15 nA IB Input Bias Current l 150 nA CMRR Common Mode Rejection Ratio VCM = –4.7V to 13V l 60 dB AVOL Large-Signal Voltage Gain VO = ±4V, RL = 10k 70 160 V/mV l 10 V/mV VO Output Voltage Swing No Load l ±4.85 V IOUT = ±5mA l ±4.20 V IOUT = ±10mA l ±3.80 V PSRR Power Supply Rejection Ratio VS = ±1.5V to ±9V l 80 dB Minimum Supply Voltage l ±1.35 V IS Supply Current 230 325 μA l 650 μA Supply Current, SHDN VPIN5 = –3V, VS = ±5V, No Load (Note 10) l 25 μA ISHDN Shutdown Pin Current VPIN5 = –4.7V, VS = ±5V, No Load (Note 10) l 0.5 nA VPIN5 = –3V, VS = ±5V, No Load (Note 10) l 12 μA Maximum Shutdown Pin Current VPIN5 = 9V, VS = ±9V (Note 10) l 45 μA Output Leakage Current VPIN5 = –7V, VS = ±9V, No Load l 3 μA VL Shutdown Pin Input Low Voltage VS = ±5V l –4.7 V VH Shutdown Pin Input High Voltage VS = ±5V l –2.8 V GBW Gain Bandwidth Product f = 5kHz 800 1300 kHz l 425 kHz SR Slew Rate AV = –1, RL = ∞, VO = 4V 0.26 0.45 V/μs Measured at VO = ±2V l 0.14 V/μs 1783fd 6
