Datasheet LT2178, LT2179 (Analog Devices) - 6
Описание17µA Max, Dual and Quad, Single Supply, Precision Op Amps
Страниц / Страница12 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. Distribution of Input. Input Bias …
Формат / Размер файлаPDF / 215 Кб
TYPICAL PERFORMANCE CHARACTERISTICS. Distribution of Input. Input Bias and Offset Currents. Offset Voltage
TYPICAL PERFORMANCE CHARACTERISTICS Distribution of Input Input Bias and Offset Currents Offset Voltage
IC OPAMP GP 2 CIRCUIT 8SO. General Purpose Amplifier 2 Circuit 8-SO. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
LT2178IS8#TRPBF
155 ₽
LT2178IS8#TRPBF
269 ₽
Рутоника
LT2178IS8#TRPBF
375 ₽
SUV System
LT2178IS8#TRPBF
LT2178/LT2179
TYPICAL PERFORMANCE CHARACTERISTICS Distribution of Input Input Bias and Offset Currents Offset Voltage Minimum Supply Voltage vs Temperature
800 100 100 VS = 5V, 0V V– = 0V VS = 5V, 0V TA = 25°C 75 2500 OP AMPS 0 600 TESTED IOS 50 –100 INPUT OFFSET CURRENT (pA) 85°C 25 400 –200 25°C –2.5 –40°C –300 NUMBER OF OP AMPS 200 –3.0 I OFFSET VOLTAGE SHIFT (μV) NONFUCTIONAL B –400 –3.5 INPUT BIAS CURRENT (nA) 0 –500 –4.0 –150 –100 –50 0 50 100 150 0 1 2 3 –50 –25 0 25 50 75 100 OFFSET VOLTAGE (μV) POSITIVE SUPPLY VOLTAGE (V) TEMPERATURE (°C) 21789 G01 21789 G02 21789 G03
Output Saturation vs Temperature vs Sink Current Short-Circuit Current 0.1Hz to 10Hz Noise
1000 20 VS = 5V, 0V TA = 25°C, VS = p2.5V ISINK = 1mA VS = p15V ISINK = 100μA 10 100 SOURCING VS = p2.5V VS = 5V, 0V 0 I CHANNEL A SINK = 1μA 10 VS = p2.5V NO LOAD –10 10k TO GROUND 1 SATURATION VOLTAGE (mV) V NOISE VOLTAGE (0.4μV/DIV) SHORT CIRCUIT CURRENT (mA) –20 S = p15V 2k TO GROUND SINKING CHANNEL B 0.1 –30 –50 –25 0 25 50 75 100 0 1 2 0 2 4 6 8 10 12 TEMPERATURE (°C) TIME FROM OUTPUT SHORT TO GROUND (MINUTES) TIME (SECONDS) 21789 G04 21789 G05 21789 G06
0.01Hz to 10Hz Noise Noise Spectrum Voltage Gain vs Frequency
1000 140 TA = 25°C, VS = p2.5V TA = 25°C TA = 25°C VS = p2.5V 120 Hz) Hz) • • 300 100 Y (nV Y (fA CURRENT NOISE 80 VS = p15V CHANNEL A 100 60 VS = 5V, 0V VOLTAGE NOISE 40 VOLTAGE GAIN (dB) 30 20 NOISE VOLTAGE (0.4μV/DIV) TAGE NOISE DENSIT 1/f CORNER VOL CURRENT NOISE DENSIT 0.5Hz 0 CHANNEL B 10 –20 0 20 40 60 80 100 120 0.1 1 10 100 1000 0.001 0.01 0.1 1 10 100 1k 10k 100k 1M TIME (SECONDS) FREQUENCY (Hz) FREQUENCY (Hz) 21789 G07 21789 G08 217879 G09 21789fc 6
