Datasheet LT2078, LT2079 (Analog Devices) - 6
ОписаниеMicropower, Dual and Quad, Single Supply, Precision Op Amps
Страниц / Страница16 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. 0.1Hz to 10Hz Noise. 0.01Hz to 10Hz …
Формат / Размер файлаPDF / 348 Кб
TYPICAL PERFORMANCE CHARACTERISTICS. 0.1Hz to 10Hz Noise. 0.01Hz to 10Hz Noise. Noise Spectrum. Long Term Stability of Two
TYPICAL PERFORMANCE CHARACTERISTICS 0.1Hz to 10Hz Noise 0.01Hz to 10Hz Noise Noise Spectrum Long Term Stability of Two
30 предложений от 17 поставщиков
Микросхема Буферный усилитель, IC OPAMP GP 200kHz 8SO
LT2078IS8#PBF
221 ₽
ЧипСити
LT2078IS8
399 ₽
Эиком
LT2078IS8#PBF
от 1 424 ₽
LT2078IS8 PBF
LT2078/LT 2079
W U TYPICAL PERFORMANCE CHARACTERISTICS 0.1Hz to 10Hz Noise 0.01Hz to 10Hz Noise Noise Spectrum
1000 TA = 25°C TA = 25°C TA = 25°C VS = ±2.5V V V CHANNEL A S = ±2.5V S = ±2.5V √Hz) √Hz) (AT VS = ±15V 300 CURRENT VOLTAGE NOISE µV/DIV) µV/DIV) NOISE IS 4% LESS CURRENT NOISE IS UNCHANGED) CHANNEL B 100 CHANNEL A 0.4µV VOLTAGE NOISE 30 NOISE VOLTAGE (0.4 NOISE VOLTAGE (0.4 VOLTAGE NOISE DENSITY (nV/ CURRENT NOISE DENSITY (fA/ 1/f CORNER CHANNEL B 0.7Hz 10 0 2 4 6 8 10 0 20 40 60 80 100 0.1 1 10 100 1000 TIME (SEC) TIME (SEC) FREQUENCY (Hz) LT2078/79 • TPC04 LT2078/79 • TPC05 LT2078/79 • TPC06
Long Term Stability of Two 10Hz Voltage Noise Distribution Representative Units (LT2078) Warm-Up Drift
35 15 0.8 T T T A = 25°C, VS = 5V, 0V A = 25°C A = 25°C VCM = 0.1V 0.7 V 30 V S = ±15V S = ±2.5V 10 µV) WARM UP DRIFT µV) 1A 0.6 AT VS = 5V, 0V IS 25 IMMEASURABLY LOW 5 0.5 20 0 0.4 2B 15 0.3 – 5 LT2079 PERCENT OF UNITS 10 1B 0.2 OFFSET VOLTAGE CHANGE ( –10 5 2A CHANGE IN OFFSET VOLTAGE ( LT2078 0.1 0 –15 0 25 30 35 40 0 1 2 3 4 5 0 1 2 3 VOLTAGE NOISE DENSITY (nV/√Hz) TIME (MONTHS) TIME AFTER POWER-ON (MINUTES) LT2078/79 • TPC07 LT2078/79 • TPC08 LT2078/79 • TPC09
Output Saturation vs Temperature Output Voltage Swing vs Minimum Supply Voltage vs Sink Current Load Current
100 1000 V+ V– = 0V ISINK = 2mA 125°C 25°C –0.1V ≤ VCM ≤ 0.4V 0 V+ – 1 –55°C µV) ISINK = 1mA 125°C ISINK = 100µA –100 100 V+ – 2 ISINK = 10µA –200 70°C V 0°C S = 5V, 0V 25°C –55°C ISINK = 1µA –300 NONFUNCTIONAL 10 V– + 2 NO LOAD 125°C INPUT OFFSET VOLTAGE ( SATURATION VOLTAGE (mV) OUTPUT VOLTAGE SWING (V) –400 V– + 1 25°C RL = 5k TO GND –55°C –500 1 V– 0 1 2 3 –50 –25 0 25 50 75 100 125 0.01 0.1 1 10 POSITIVE SUPPLY VOLTAGE (V) TEMPERATURE (°C) SOURCING OR SINKING LOAD CURRENT (mA) LT2078/79 • TPC11 LT2078/79 • TPC11.5 LT2078/79 • TPC10 20789fa 6
