Datasheet LT1498, LT1499 (Analog Devices) - 4
Описание10MHz, 6V/µs, Dual/Quad Rail-to-Rail Input and Output Precision C-Load Op Amps
Страниц / Страница24 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 293 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the temperature range
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the temperature range
24 предложений от 14 поставщиков
LT1499HS#PBF
469 ₽
LT1499HS#TRPBF
790 ₽
LT1499HS#PBF
от 1 874 ₽
LT1499HS#TRPBF
АЦП азиатских производителей
LT1498/LT1499
l
denotes the specifi cations which apply over the temperature range 0°C < TA < 70°C. VS = 5V, 0V; VS = 3V, 0V; VCM = VOUT = half supply, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = V+ l 175 650 μV VCM = V– + 0.1V l 175 650 μV VOS TC Input Offset Voltage Drift (Note 3) l 0.5 2.5 μV/°C VCM = V+ l 1.5 4.0 μV/°C ΔVOS Input Offset Voltage Shift VCM = V– + 0.1V to V+ l 170 600 μV Input Offset Voltage Match (Channel-to-Channel) VCM = V– + 0.1V, V+ (Note 5) l 200 900 μV IB Input Bias Current VCM = V+ l 0 275 780 nA VCM = V– + 0.1V l –780 –275 0 nA ΔIB Input Bias Current Shift VCM = V– + 0.1V to V+ l 550 1560 nA Input Bias Current Match (Channel-to-Channel) VCM = V+ (Note 5) l 0 15 170 nA VCM = V– + 0.1V (Note 5) l –170 –15 0 nA IOS Input Offset Current VCM = V+ l 10 85 nA VCM = V– + 0.1V l 10 85 nA ΔIOS Input Offset Current Shift VCM = V– + 0.1V to V+ l 20 170 nA AVOL Large-Signal Voltage Gain VS = 5V, VO = 75mV to 4.8V, RL = 10k l 500 2500 V/mV VS = 3V, VO = 75mV to 2.8V, RL = 10k l 400 2000 V/mV CMRR Common Mode Rejection Ratio VS = 5V, VCM = V– + 0.1V to V+ l 78 89 dB VS = 3V, VCM = V– + 0.1V to V+ l 73 85 dB CMRR Match (Channel-to-Channel) (Note 5) VS = 5V, VCM = V– + 0.1V to V+ l 74 90 dB VS = 3V, VCM = V– + 0.1V to V+ l 69 86 dB PSRR Power Supply Rejection Ratio VS = 2.3V to 12V, VCM = VO = 0.5V l 86 102 dB PSRR Match (Channel-to-Channel) (Note 5) VS = 2.3V to 12V, VCM = VO = 0.5V l 80 102 dB VOL Output Voltage Swing (Low) (Note 6) No Load l 17 35 mV ISINK = 0.5mA l 40 80 mV ISINK = 2.5mA l 110 220 mV VOH Output Voltage Swing (High) (Note 6) No Load l 3.5 15 mV ISOURCE = 0.5mA l 55 120 mV ISOURCE = 2.5mA l 160 300 mV ISC Short-Circuit Current VS = 5V l ±12 ±23 mA VS = 3V l ±10 ±20 mA IS Supply Current per Amplifi er l 1.9 2.6 mA GBW Gain-Bandwidth Product (Note 7) l 6.1 9 MHz SR Slew Rate (Note 8) VS = 5V, AV = –1, RL = Open, VO = 4V l 2.5 4.0 V/μs VS = 3V, AV = –1, RL = Open l 2.2 3.5 V/μs 14989fg 4
