Datasheet LT1498, LT1499 (Analog Devices) - 5
Описание10MHz, 6V/µs, Dual/Quad Rail-to-Rail Input and Output Precision C-Load Op Amps
Страниц / Страница24 / 5 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 293 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the temperature range
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the temperature range
38 предложений от 16 поставщиков
LT1498CS8#TRPBF
224 ₽
LT1498CS8#TRPBF
от 835 ₽
LT1498CS8#TRPBF
2 614 ₽
SUV System
LT1498CS8#TRPBF
АЦП азиатских производителей
LT1498/LT1499
l
denotes the specifi cations which apply over the temperature range –40°C < TA < 85°C. VS = 5V, 0V; VS = 3V, 0V; VCM = VOUT = half supply, unless otherwise noted. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = V+ l 250 750 μV VCM = V– + 0.1V l 250 750 μV VOS TC Input Offset Voltage Drift (Note 3) l 0.5 2.5 μV/°C VCM = V+ l 1.5 4.0 μV/°C ΔVOS Input Offset Voltage Shift VCM = V– + 0.1V to V+ l 250 650 μV Input Offset Voltage Match (Channel-to-Channel) VCM = V– + 0.1V, V+ (Note 5) l 300 1500 μV IB Input Bias Current VCM = V+ l 0 350 975 nA VCM = V– + 0.1V l –975 –350 0 nA ΔIB Input Bias Current Shift VCM = V– + 0.1V to V+ l 700 1950 nA Input Bias Current Match (Channel-to-Channel) VCM = V+ (Note 5) l 0 30 180 nA VCM = V– + 0.1V (Note 5) l –180 –30 0 nA IOS Input Offset Current VCM = V+ l 15 110 nA VCM = V– + 0.1V l 15 110 nA ΔIOS Input Offset Current Shift VCM = V– + 0.1V to V+ l 30 220 nA AVOL Large-Signal Voltage Gain VS = 5V, VO = 75mV to 4.8V, RL = 10k l 400 2500 V/mV VS = 3V, VO = 75mV to 2.8V, RL = 10k l 300 2000 V/mV CMRR Common Mode Rejection Ratio VS = 5V, VCM = V– + 0.1V to V+ l 77 86 dB VS = 3V, VCM = V– + 0.1V to V+ l 73 81 dB CMRR Match (Channel-to-Channel) (Note 5) VS = 5V, VCM = V– + 0.1V to V+ l 72 86 dB VS = 3V, VCM = V– + 0.1V to V+ l 69 83 dB PSRR Power Supply Rejection Ratio VS = 2.5V to 12V, VCM = VO = 0.5V l 86 100 dB PSRR Match (Channel-to-Channel) (Note 5) VS = 2.5V to 12V, VCM = VO = 0.5V l 80 100 dB VOL Output Voltage Swing (Low) (Note 6) No Load l 18 40 mV ISINK = 0.5mA l 45 80 mV ISINK = 2.5mA l 110 220 mV VOH Output Voltage Swing (High) (Note 6) No Load l 3.5 15 mV ISOURCE = 0.5mA l 60 120 mV ISOURCE = 2.5mA l 170 300 mV ISC Short-Circuit Current VS = 5V l ±7.5 ±15 mA VS = 3V l ±7.5 ±15 mA IS Supply Current per Amplifi er l 2.0 2.7 mA GBW Gain-Bandwidth Product (Note 7) l 5.8 8.5 MHz SR Slew Rate (Note 8) VS = 5V, AV = –1, RL = Open, VO = 4V l 2.2 3.6 V/μs VS = 3V, AV = –1, RL = Open l 1.9 3.2 V/μs 14989fg 5
