Datasheet LT1498, LT1499 (Analog Devices) - 7
Описание10MHz, 6V/µs, Dual/Quad Rail-to-Rail Input and Output Precision C-Load Op Amps
Страниц / Страница24 / 7 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 293 Кб
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the temperature range
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the temperature range
26 предложений от 15 поставщиков
LT1498HS8#PBF
157 ₽
LT1498HS8#PBF
261 ₽
LT1498HS8#TRPBF
440 ₽
727GS
LT1498HS8#TRPBF
от 518 ₽
АЦП азиатских производителей
LT1498/LT1499
l
denotes the specifi cations which apply over the temperature range –55°C < TA < 125°C. VS = 5V, 0V; VS = 3V, 0V; VCM = VOUT = half supply, unless otherwise noted. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = V+ – 0.5V l 300 1100 μV VCM = V– + 0.5V l 300 1100 μV VOS TC Input Offset Voltage Drift (Note 3) l 0.5 μV/°C VCM = V+ – 0.5V l 1.5 μV/°C ΔVOS Input Offset Voltage Shift VCM = V– + 0.5V to V+ – 0.5V l 250 2300 μV Input Offset Voltage Match (Channel-to-Channel) VCM = V– + 0.5V, V+ – 0.5V (Note 5) l 300 1900 μV IB Input Bias Current VCM = V+ – 0.5V l 0 450 1100 nA VCM = V– + 0.5V l –1100 –450 0 nA ΔIB Input Bias Current Shift VCM = V– + 0.5V to V+ – 0.5V l 900 2200 nA Input Bias Current Match (Channel-to-Channel) VCM = V+ – 0.5V (Note 5) l 0 40 400 nA VCM = V– + 0.5V (Note 5) l –400 –40 0 nA IOS Input Offset Current VCM = V+ – 0.5V l 40 300 nA VCM = V– + 0.5V l 40 300 nA ΔIOS Input Offset Current Shift VCM = V– + 0.5V to V+ – 0.5V l 80 600 nA AVOL Large-Signal Voltage Gain VS = 5V, VO = 0.5V to 4.5V, RL = 10k l 40 210 V/mV VS = 3V, VO = 0.5V to 2.5V, RL = 10k l 20 210 V/mV CMRR Common Mode Rejection Ratio VS = 5V, VCM = V– + 0.5V to V+ – 0.5V l 66 80 dB VS = 3V, VCM = V– + 0.5V to V+ – 0.5V l 62 75 dB CMRR Match (Channel-to-Channel) (Note 5) VS = 5V, VCM = V– + 0.5V to V+ – 0.5V l 62 80 dB VS = 3V, VCM = V– + 0.5V to V+ – 0.5V l 58 75 dB PSRR Power Supply Rejection Ratio VS = 2.5V to 12V, VCM = VO = 0.5V l 86 100 dB PSRR Match (Channel-to-Channel) (Note 5) VS = 2.5V to 12V, VCM = VO = 0.5V l 80 100 dB VOL Output Voltage Swing (Low) (Note 6) No Load l 22 50 mV ISINK = 0.5mA l 45 80 mV ISINK = 2.5mA l 110 220 mV VOH Output Voltage Swing (High) (Note 6) No Load l 3.5 20 mV ISOURCE = 0.5mA l 60 120 mV ISOURCE = 2.5mA l 170 350 mV ISC Short-Circuit Current VS = 5V l ±5 ±15 mA VS = 3V l ±5 ±15 mA IS Supply Current per Amplifi er l 2.4 3.0 mA GBW Gain-Bandwidth Product (Note 7) l 5.8 8.5 MHz SR Slew Rate (Note 8) VS = 5V, AV = –1, RL = Open, VO = 4V l 2.0 3.6 V/μs VS = 3V, AV = –1, RL = Open l 1.7 3.2 V/μs 14989fg 7
