Datasheet LT1001 (Analog Devices) - 7
ОписаниеPrecision Operational Amplifier
Страниц / Страница16 / 7 — APPLICATIONS INFORMATION. Offset Voltage Adjustment. 0.1Hz to 10Hz Noise …
Формат / Размер файлаPDF / 202 Кб
APPLICATIONS INFORMATION. Offset Voltage Adjustment. 0.1Hz to 10Hz Noise Test Circuit. Improved Sensitivity Adjustment
APPLICATIONS INFORMATION Offset Voltage Adjustment 0.1Hz to 10Hz Noise Test Circuit Improved Sensitivity Adjustment
46 предложений от 24 поставщиков
LT1001CN8#PBF
33 ₽
LT1001CN8#PBF
от 60 ₽
LT1001CN8#PBF
349 ₽
LT1001CN8#
LT1001
U U W U APPLICATIONS INFORMATION Offset Voltage Adjustment
adjusted to 300 µV, the change in drift will be 1 µV/°C. The adjustment range with a 10k or 20k pot is approximately The input offset voltage of the LT1001, and its drift with ±2.5mV. If less adjustment range is needed, the sensitivity temperature, are permanently trimmed at wafer test to a and resolution of the nulling can be improved by using a low level. However, if further adjustment of Vos is neces- smaller pot in conjunction with fixed resistors. The ex- sary, nulling with a 10k or 20k potentiometer will not ample below has an approximate null range of ±100 µV. degrade drift with temperature. Trimming to a value other than zero creates a drift of (Vos/300)µV/°C, e.g., if Vos is
0.1µF
VOLTAGE GAIN = 50,000 7.5k 100kΩ (PEAK-TO-PEAK NOISE MEASURED IN 10 SEC INTERVAL) 1k +15V 10Ω – 2kΩ 1 7.5k LT1001 + 22µF 2 – + 4.3k 8 LT1001 SCOPE 7 4.7 µF INPUT LT1001 OUTPUT – × 1 6 DEVICE 3 + R UNDER 100k 2.2µF IN = 1MΩ 4 TEST –15V 1001 F02 110k 0.1 µF 24.3k 1001 F03 The device under test should be warmed up for three minutes and shielded from air currents.
DC Stabilized 1000v/
µ
sec Op Amp
2.2µF +15V TANTALUM + 3.9k 300Ω 0.1µF 1N914 200 2N5486 Ω* 200pF 2N5160 0.01µF 22µF TANTALUM + 2N3866 33Ω 1k 2N4440 30k 1.8k RIN –15V 1k 10k 3 INPUT + 6 15pF LT1001 0.001µF 390Ω 2N3904 2 – 2N3904 0.5Ω 30k 470Ω OUTPUT 0.5Ω 22Ω 2N5160 2N3906 0.01µF 2N3866 2N4440 200pF 22µF TANTALUM – + 3.9k 1.2k 200Ω* 15-60pF TUSONIX # 519-3188 1N914 300Ω 0.1µF –15V 1001 F04 1k FULL POWER *ADJUST FOR Rf BANDWIDTH 8MHz BEST SQUARE WAVE AT OUTPUT 1001fb 7
