Datasheet LTC2066, LTC2067 (Analog Devices) - 5
Описание10μA Supply Current, Low IB, Zero-Drift Operational Amplifier
Страниц / Страница28 / 5 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
ВерсияA
Формат / Размер файлаPDF / 4.6 Мб
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
34 предложений от 13 поставщиков
LTC2066IS5#TRPBF
116 ₽
Зенер
Россия и страны ТС
LTC2066IS5#TRPBF
от 123 ₽
Элитан
LTC2066IS5
292 ₽
LTC2066IS5#TRMPBF
от 323 ₽
LTC2066/LTC2067
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. Unless otherwise noted, VS = 5V, VCM = VOUT = VS/2, VSHDN = 5V, RL to VS/2. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VH SHDN Pin Threshold, Logic High (Referred to V–) l 1.8 V VL SHDN Pin Threshold, Logic Low (Referred to V–) l 0.8 V ISHDN SHDN Pin Current VSHDN = 0V l –150 –20 nA
Note 1:
Note 5:
Thermal resistance varies with the amount of PC board metal may cause permanent damage to the device. Exposure to any Absolute connected to the package. The specified values are for short traces Maximum Rating condition for extended periods may affect device connected to the leads. reliability and lifetime.
Note 6:
These parameters are guaranteed by design. Thermocouple effects
Note 2:
The inputs are protected by two series connected ESD protection preclude measurements of these voltage levels during automated testing. diodes to each power supply. The input current should be limited to less than VOS is measured to a limit determined by test equipment capability. 10mA. The input voltage should not exceed 300mV beyond the power supply.
Note 7:
Input Bias Current, Input Offset Current and Open Loop Gain are
Note 3:
A heat sink may be required to keep the junction temperature below only production tested at 5V. Input Bias Current and Input Offset Current the absolute maximum rating when the output is shorted indefinitely. at 1.8V are expected to meet 5V specifications.
Note 4:
The LTC2066I/LTC2067I is guaranteed to meet specified
Note 8:
Minimum specifications for these parameters are limited by noise performance from –40°C to 85°C. The LTC2066H/LTC2067H is guaranteed and the capabilities of the automated test system. to meet specified performance from –40°C to 125°C. Rev A For more information www.analog.com 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Typical Application Related Parts
