Datasheet LT1636 (Analog Devices) - 5
ОписаниеOver-The-Top Micropower Rail-to-Rail Input and Output Op Amp
Страниц / Страница16 / 5 — 15V ELECTRICAL CHARACTERISTICS. The
Формат / Размер файлаPDF / 403 Кб
15V ELECTRICAL CHARACTERISTICS The
IC OPAMP GP 1 CIRCUIT 8MSOP. General Purpose Amplifier 1 Circuit Rail-to-Rail 8-MSOP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer...
Рутоника
LT1636IMS8#TRPBF
196 ₽
LT1636IMS8#TRPBF
LT1636IMS8#TRPBF
LT1636IMS8#TRPBF
LT1636 ±
denotes the specifications which apply over the full operating temperature range of –40
C
TA
85
C, otherwise specifications are at TA = 25
C. VS =
15V, VCM = 0V, VOUT = 0V, VSHDN = V – unless otherwise specified. (Note 4) LT1636C/LT1636I SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
ISC Short-Circuit Current (Note 2) Short to GND ±18 ±30 mA 0°C ≤ TA ≤ 70°C ● ±15 mA – 40°C ≤ TA ≤ 85°C ● ±10 mA PSRR Power Supply Rejection Ratio VS = ±1.35V to ±22V ● 90 114 dB IS Supply Current 50 70 µA ● 85 µA Positive Supply Current, SHDN VPIN5 = – 20V, VS = ±22V, No Load ● 12 30 µA ISHDN Shutdown Pin Current VPIN5 = – 21.7V, VS = ±22V, No Load ● 0.7 15 nA VPIN5 = – 20V, VS = ±22V, No Load ● 1.2 8 µA Maximum Shutdown Pin Current VPIN5 = 32V, VS = ±22V ● 27 150 µA Output Leakage Current, SHDN VPIN5 = – 20V, VS = ±22V, No Load ● 0.1 2 µA GBW Gain Bandwidth Product f = 1kHz 125 220 kHz 0°C ≤ TA ≤ 70°C ● 110 kHz – 40°C ≤ TA ≤ 85°C ● 100 kHz SR Slew Rate AV = – 1, RL = ∞, VO = ±10V Measured at ±5V 0.0375 0.075 V/µs 0°C ≤ TA ≤ 70°C ● 0.033 V/µs – 40°C ≤ TA ≤ 85°C ● 0.030 V/µs
U 3V A D 5V ELECTRICAL CHARACTERISTICS The
C
TA
125
C. VS = 3V, 0V; VS = 5V, 0V; VCM = VOUT = half supply unless otherwise specified. (Note 4) LT1636H SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 50 325 µV ● 3 mV Input Offset Voltage Drift (Note 9) ● 3 10 µV/°C IOS Input Offset Current ● 3 nA VCM = 44V (Note 5) ● 1 µA IB Input Bias Current ● 30 nA VCM = 44V (Note 5) ● 10 µA Input Voltage Range ● 0.3 44 V CMRR Common Mode Rejection Ratio VCM = 0.3V to VCC – 1V ● 72 dB (Note 5) VCM = 0.3V to 44V ● 74 dB AVOL Large-Signal Voltage Gain VS = 3V, VO = 500mV to 2.5V, RL = 10k 200 1300 V/mV ● 20 V/mV VS = 5V, VO = 500mV to 4.5V, RL = 10k 400 2000 V/mV ● 35 V/mV VOL Output Voltage Swing LOW No Load ● 15 mV ISINK = 2.5mA ● 875 mV VOH Output Voltage Swing HIGH VS = 3V, No Load ● 2.925 V VS = 3V, ISOURCE = 5mA ● 2.35 V VS = 5V, No Load ● 4.925 V VS = 5V, ISOURCE = 10mA ● 4.10 V PSRR Power Supply Rejection Ratio VS = 2.7V to 12.5V, VCM = VO = 1V ● 80 dB Minimum Supply Voltage ● 2.7 V 1636fc 5
