Datasheet ADP5301 (Analog Devices) - 10
Описание50 mA/500 mA, High Efficiency, Ultralow Power Step-Down Regulator
Страниц / Страница21 / 10 — ADP5301. Data Sheet. 801. 810. 808. ACTIVE TO STANDBY. 806. 800. 804. …
ВерсияC
Формат / Размер файлаPDF / 729 Кб
ADP5301. Data Sheet. 801. 810. 808. ACTIVE TO STANDBY. 806. 800. 804. STANDBY TO ACTIVE. 802. O 799. DBACK V. 798. F 798. 796. 794. 797. 792. –40. +25. +85. +125
ADP5301 Data Sheet 801 810 808 ACTIVE TO STANDBY 806 800 804 STANDBY TO ACTIVE 802 O 799 DBACK V 798 F 798 796 794 797 792 –40 +25 +85 +125
28 предложений от 8 поставщиков
Управление питанием (PMIC)
Зенер
Россия и страны ТС
ADP5301ACBZ-4-R7
от 282 ₽
ADP5301ACBZ-4-R7
от 354 ₽
Hi-Tech Circuit Group
ADP5301ACBZ-4-R7
ADP5301ACBZ-4-R7
ADP5301 Data Sheet 801 810 808 ACTIVE TO STANDBY ) ) 806 800 mV mV ( ( E E 804 AG AG STANDBY TO ACTIVE T T L L 802 O 799 O 800 DBACK V DBACK V 798 E E E E F 798 F 796 794 797 792
016 019
–40 +25 +85 +125 –40 +25 +85 +125 TEMPERATURE (°C)
13169-
TEMPERATURE (°C)
13169- Figure 16. Feedback Voltage vs. Temperature, PWM Mode Figure 19. Feedback Voltage vs. Temperature, Hysteresis Mode
700 400 –40ºC –40ºC 600 +25ºC 350 +25ºC ) +125ºC ) +125ºC (mΩ 500 (mΩ 300 H L N) N) O O ( ( DS 400 DS 250 R E R IDE D S -SI H- 300 W 200 G O HI L 200 150 100 100
017 020
2.3 2.9 3.5 4.1 4.7 5.3 5.9 6.5 2.3 2.9 3.5 4.1 4.7 5.3 5.9 6.5 V
13169-
IN (V) V
13169-
IN (V)
Figure 17. High-Side RDS (ON) H vs. VIN Figure 20. Low-Side RDS (ON) L vs. VIN
1090 1200 1150 –40ºC +25ºC 1040 +125ºC 1100 mA) mA) ( ( IT IT 1050 IM 990 IM L L NT NT 1000 940 950 AK CURRE AK CURRE E E P P 900 890 850 840 800
018 021
–40 +25 +85 +125 2.3 2.9 3.5 4.1 4.7 5.3 5.9 6.5 TEMPERATURE (°C)
13169-
V
13169-
IN (V)
Figure 18. Peak Current Limit vs. Temperature Figure 21. Peak Current Limit vs. VIN Rev. B | Page 10 of 21 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BUCK REGULATOR OPERATION MODES PWM Mode Hysteresis Mode Mode Selection OSCILLATOR AND SYNCHRONIZATION ADJUSTABLE AND FIXED OUTPUT VOLTAGES UNDERVOLTAGE LOCKOUT (UVLO) ENABLE/DISABLE CURRENT LIMIT SHORT-CIRCUIT PROTECTION SOFT START STARTUP WITH A PRECHARGED OUTPUT 100% DUTY CYCLE OPERATION ACTIVE DISCHARGE VOUTOK FUNCTION THERMAL SHUTDOWN APPLICATIONS INFORMATION EXTERNAL COMPONENT SELECTION SELECTING THE INDUCTOR OUTPUT CAPACITOR INPUT CAPACITOR EFFICIENCY Power Switch Conduction Losses Inductor Losses Driver Losses Transition Losses PRINTED CIRCUIT BOARD (PCB) LAYOUT RECOMMENDATIONS TYPICAL APPLICATION CIRCUITS FACTORY PROGRAMMABLE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
