Datasheet ADP5053 (Analog Devices) - 8 Производитель Analog Devices Описание Integrated Power Solution with Quad Buck Regulators and Supervisory Circuits Страниц / Страница 37 / 8 — ADP5053. Data Sheet. SUPERVISORY SPECIFICATIONS. Table 4. Parameter. … Версия C Формат / Размер файла PDF / 1.0 Мб Язык документа английский
ADP5053. Data Sheet. SUPERVISORY SPECIFICATIONS. Table 4. Parameter. Symbol Min. Typ. Max. Unit. Test Conditions/Comments
Скачать PDF
34 предложений от 15 поставщиков
Микросхема Чип управления батареи, ANALOG DEVICES ADP5053ACPZ-R7 Power Management IC, Quad Buck Regulators, Supervisory Circuits, 15V, 250kHz to 1.4MHz, LFCSP-48
ADP5053ACPZ-R7 Analog Devices от 202 ₽ КупитьADP5053ACPZ-R7 Analog Devices 290 ₽ КупитьADP5053ACPZ-R7 Analog Devices от 1 189 ₽ КупитьADP5053ACPZ-R7 Analog Devices по запросу Купить
Модельный ряд для этого даташита Текстовая версия документа ADP5053 Data Sheet SUPERVISORY SPECIFICATIONS VIN = 12 V, VVREG = 5.1 V, TJ = −40°C to +125°C for minimum and maximum specifications, and TA = 25°C for typical specifications, unless otherwise noted.Table 4. Parameter Symbol Min Typ Max Unit Test Conditions/Comments THRESHOLD VOLTAGE VTH 0.494 0.500 0.505 V RESET TIMEOUT PERIOD tRP Option 0 1.05 1.4 1.97 ms Option 1 21 28 38 ms Option 2 160 200 260 ms Option 3 1.15 1.6 2.17 sec VCC TO RESET DELAY tRD 80 µs VTH falling at 1 mV/µs WATCHDOG INPUT Watchdog Timeout Period tWD Option 0 4.8 6.3 8 ms Option 1 79 102 135 ms Option 2 1.14 1.6 2.15 sec Option 3 25.6 sec WDI Pulse Width 80 ns WDI Input Threshold 0.4 1.2 V WDI Input Current (Source) 8.5 14 18.5 µA VWDI = VCC, time average WDI Input Current (Sink) −15 −22 −30 µA VWDI = 0 V, time average MANUAL RESET INPUT MR Input Pulse Width 1 µs MR Glitch Rejection 280 ns MR Pull-Up Resistance 32 55 80 kΩ MR to Reset Delay 310 ns Rev. C | Page 8 of 37 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY DETAILED FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS BUCK REGULATOR SPECIFICATIONS SUPERVISORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BUCK REGULATOR OPERATIONAL MODES Pulse-Width Modulation (PWM) Mode Power Save Mode (PSM) Forced PWM and Automatic PWM/PSM Modes ADJUSTABLE AND FIXED OUTPUT VOLTAGES INTERNAL REGULATORS (VREG AND VDD) SEPARATE SUPPLY APPLICATIONS LOW-SIDE DEVICE SELECTION BOOTSTRAP CIRCUITRY ACTIVE OUTPUT DISCHARGE SWITCH PRECISION ENABLING OSCILLATOR Phase Shift SYNCHRONIZATION INPUT/OUTPUT SOFT START PARALLEL OPERATION STARTUP WITH PRECHARGED OUTPUT CURRENT-LIMIT PROTECTION FREQUENCY FOLDBACK Pulse Skip Mode Under Maximum Duty Cycle HICCUP PROTECTION LATCH-OFF PROTECTION Short-Circuit Latch-Off Mode Overvoltage Latch-Off Mode UNDERVOLTAGE LOCKOUT (UVLO) POWER-GOOD FUNCTION THERMAL SHUTDOWN SUPERVISORY CIRCUIT Reset Output Watchdog Input Manual Reset Input Processor Manual Reset Mode Power On/Off Switch Mode APPLICATIONS INFORMATION ADIsimPower DESIGN TOOL PROGRAMMING THE ADJUSTABLE OUTPUT VOLTAGE VOLTAGE CONVERSION LIMITATIONS CURRENT-LIMIT SETTING SOFT START SETTING INDUCTOR SELECTION OUTPUT CAPACITOR SELECTION INPUT CAPACITOR SELECTION LOW-SIDE POWER DEVICE SELECTION PROGRAMMING THE UVLO INPUT COMPENSATION COMPONENTS DESIGN POWER DISSIPATION Buck Regulator Power Dissipation Power Switch Conduction Loss (PCOND) Switching Loss (PSW) Transition Loss (PTRAN) Thermal Shutdown JUNCTION TEMPERATURE DESIGN EXAMPLE SETTING THE SWITCHING FREQUENCY SETTING THE OUTPUT VOLTAGE SETTING THE CURRENT LIMIT SELECTING THE INDUCTOR SELECTING THE OUTPUT CAPACITOR SELECTING THE LOW-SIDE MOSFET DESIGNING THE COMPENSATION NETWORK SELECTING THE SOFT START TIME SELECTING THE INPUT CAPACITOR RECOMMENDED EXTERNAL COMPONENTS CIRCUIT BOARD LAYOUT RECOMMENDATIONS TYPICAL APPLICATION CIRCUITS FACTORY DEFAULT OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
