Datasheet ADP5052 (Analog Devices) - 8
Описание5-Channel Integrated Power Solution with Quad Buck Regulators and 200 mA LDO Regulator
Страниц / Страница36 / 8 — ADP5052. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 5. Parameter. Rating. …
ВерсияD
ADP5052. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 5. Parameter. Rating. THERMAL RESISTANCE. Table 6. Thermal Resistance
ADP5052 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 5 Parameter Rating THERMAL RESISTANCE Table 6 Thermal Resistance
48 предложений от 22 поставщиков
Микросхема Чип управления батареи, ANALOG DEVICES ADP5052ACPZ-R7 Power Management IC, 5Channel, Quad Buck Regulators, 200mA LDO Regulator, 15V, LFCSP-48
ADP5052ACPZ-R7
542 ₽
ADP5052ACPZ-R7
740 ₽
Зенер
Россия и страны ТС
ADP5052ACPZ-R7
от 1 154 ₽
Hi-Tech Circuit Group
ADP5052ACPZ-R7
ADP5052 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 5.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a PVIN1 to PGND −0.3 V to +18 V stress rating only; functional operation of the product at these PVIN2 to PGND −0.3 V to +18 V or any other conditions above those indicated in the operational PVIN3 to PGND3 −0.3 V to +18 V section of this specification is not implied. Operation beyond PVIN4 to PGND4 −0.3 V to +18 V the maximum operating conditions for extended periods may PVIN5 to GND −0.3 V to +6.5 V affect product reliability. SW1 to PGND −0.3 V to +18 V
THERMAL RESISTANCE
SW2 to PGND −0.3 V to +18 V θ SW3 to PGND3 −0.3 V to +18 V JA is specified for the worst-case conditions, that is, a device SW4 to PGND4 −0.3 V to +18 V soldered in a circuit board for surface-mount packages. PGND to GND −0.3 V to +0.3 V
PGND3 to GND −0.3 V to +0.3 V
Package Type θJA θJC Unit
PGND4 to GND −0.3 V to +0.3 V 48-Lead LFCSP 27.87 2.99 °C/W BST1 to SW1 −0.3 V to +6.5 V BST2 to SW2 −0.3 V to +6.5 V
ESD CAUTION
BST3 to SW3 −0.3 V to +6.5 V BST4 to SW4 −0.3 V to +6.5 V DL1 to PGND −0.3 V to +6.5 V DL2 to PGND −0.3 V to +6.5 V SS12, SS34 to GND −0.3 V to +6.5 V EN1, EN2, EN3, EN4, EN5 to GND −0.3 V to +6.5 V VREG to GND −0.3 V to +6.5 V SYNC/MODE to GND −0.3 V to +6.5 V VOUT5, FB5 to GND −0.3 V to +6.5 V RT to GND −0.3 V to +3.6 V PWRGD to GND −0.3 V to +6.5 V FB1, FB2, FB3, FB4 to GND1 −0.3 V to +3.6 V FB2 to GND2 −0.3 V to +6.5 V FB4 to GND2 −0.3 V to +7 V COMP1, COMP2, COMP3, COMP4 −0.3 V to +3.6 V to GND VDD to GND −0.3 V to +3.6 V Storage Temperate Range −65°C to +150°C Operational Junction Temperature −40°C to +125°C Range 1 This rating applies to the adjustable output voltage models of the ADP5052. 2 This rating applies to the fixed output voltage models of the ADP5052. Rev. D | Page 8 of 36 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY DETAILED FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS BUCK REGULATOR SPECIFICATIONS LDO REGULATOR SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BUCK REGULATOR OPERATIONAL MODES PWM Mode PSM Mode Forced PWM and Automatic PWM/PSM Modes ADJUSTABLE AND FIXED OUTPUT VOLTAGES INTERNAL REGULATORS (VREG AND VDD) SEPARATE SUPPLY APPLICATIONS LOW-SIDE DEVICE SELECTION BOOTSTRAP CIRCUITRY ACTIVE OUTPUT DISCHARGE SWITCH PRECISION ENABLING OSCILLATOR Phase Shift SYNCHRONIZATION INPUT/OUTPUT SOFT START PARALLEL OPERATION STARTUP WITH PRECHARGED OUTPUT CURRENT-LIMIT PROTECTION FREQUENCY FOLDBACK Pulse Skip Mode Under Maximum Duty Cycle HICCUP PROTECTION LATCH-OFF PROTECTION Short-Circuit Latch-Off Mode Overvoltage Latch-Off Mode UNDERVOLTAGE LOCKOUT (UVLO) POWER-GOOD FUNCTION THERMAL SHUTDOWN LDO REGULATOR APPLICATIONS INFORMATION ADIsimPower DESIGN TOOL PROGRAMMING THE ADJUSTABLE OUTPUT VOLTAGE VOLTAGE CONVERSION LIMITATIONS CURRENT-LIMIT SETTING SOFT START SETTING INDUCTOR SELECTION OUTPUT CAPACITOR SELECTION INPUT CAPACITOR SELECTION LOW-SIDE POWER DEVICE SELECTION PROGRAMMING THE UVLO INPUT COMPENSATION COMPONENTS DESIGN POWER DISSIPATION Buck Regulator Power Dissipation Power Switch Conduction Loss (PCOND) Switching Loss (PSW) Transition Loss (PTRAN) Thermal Shutdown LDO Regulator Power Dissipation JUNCTION TEMPERATURE DESIGN EXAMPLE SETTING THE SWITCHING FREQUENCY SETTING THE OUTPUT VOLTAGE SETTING THE CURRENT LIMIT SELECTING THE INDUCTOR SELECTING THE OUTPUT CAPACITOR SELECTING THE LOW-SIDE MOSFET DESIGNING THE COMPENSATION NETWORK SELECTING THE SOFT START TIME SELECTING THE INPUT CAPACITOR RECOMMENDED EXTERNAL COMPONENTS CIRCUIT BOARD LAYOUT RECOMMENDATIONS TYPICAL APPLICATION CIRCUITS FACTORY DEFAULT OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
