Datasheet ADP5023 (Analog Devices) - 8
ОписаниеDual 3 MHz, 800 mA Buck Regulator with One 300 mA LDO
Страниц / Страница28 / 8 — ADP5023. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 3.310. 140. …
ВерсияE
Формат / Размер файлаPDF / 892 Кб
ADP5023. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 3.310. 140. –40°C. 3.305. 120. 3.300. +25°C. 100. 3.295. (V). 3.290. CURRE. UT O. +85°C. 3.285
ADP5023 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 3.310 140 –40°C 3.305 120 3.300 +25°C 100 3.295 (V) 3.290 CURRE UT O +85°C 3.285
VIN1 = VIN2 = VIN3 = 3.6 V, TA = 25°C, unless otherwise noted.
3.310 140 –40°C 3.305 120 A) 3.300 µ +25°C ( 100 NT 3.295 80 (V) 3.290 CURRE UT O NT V 60 +85°C CE 3.285 S E UI 40 3.280 Q 20 3.275 0 3.270 2.3 2.8 3.3 3.8 4.3 4.8 5.3
139
0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8
058
INPUT VOLTAGE (V) I
09889-
OUT (A)
09889- Figure 3. System Quiescent Current vs. Input Voltage, VOUT1 = 3.3 V, Figure 6. BUCK1 Load Regulation Across Temperature, VIN = 4.2 V, VOUT2 = 1.8 V, VOUT3 = 1.2 V, VOUT4 = 3.3 V, All Channels Unloaded VOUT1 = 3.3 V, PWM Mode
1.812 T 1.810 –40°C SW 4 1.808 +25°C IOUT 2 1.806 (V) UT O VOUT V 1.804 1 +85°C EN 1.802 3 1.800 1.798 CH1 2.00V CH2 50.0mA Ω M 40.0µs A CH3 2.2V
021
057
CH3 5.00V CH4 5.00V T 11.20% I
09889-
OUT (A)
09889- Figure 4. BUCK1 Startup, VOUT1 = 1.8 V, IOUT1 = 5 mA Figure 7. BUCK2 Load Regulation Across Temperature, VIN = 3.6 V, VOUT2 = 1.8 V, PWM Mode
0.808 T 0.807 SW 4 IOUT 0.806 +25°C 2 –40°C (V) 0.805 UT O VOUT V 1 0.804 +85°C EN 0.803 3 0.802 CH1 2.00V CH2 50.0mA Ω M 40.0µs A CH3 2.2V
020
054
09889-
OUT (A)
09889- Figure 5. BUCK2 Startup, VOUT2 = 3.3 V, IOUT2 = 10 mA Figure 8. BUCK1 Load Regulation Across Temperature, VIN = 3.6 V, VOUT1 = 0.8 V, PWM Mode Rev. D | Page 8 of 28 Document Outline Features Applications General Description Typical Application Circuit Revision History Specifications General Specifications BUCK1 and BUCK2 Specifications LDO Specifications Input and Output Capacitor, Recommended Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Power Management Unit Thermal Protection Undervoltage Lockout Enable/Shutdown BUCK1 and BUCK2 Control Scheme PWM Mode Power Save Mode (PSM) PSM Current Threshold Oscillator/Phasing of Inductor Switching Short-Circuit Protection Soft Start Current Limit 100% Duty Operation Active Pull-Downs LDO Applications Information Buck External Component Selection Feedback Resistors Inductor Output Capacitor Input Capacitor LDO External Component Selection Feedback Resistors Output Capacitor Input Bypass Capacitor Input and Output Capacitor Properties Power Dissipation and Thermal Considerations Buck Regulator Power Dissipation LDO Regulator Power Dissipation Junction Temperature PCB Layout Guidelines Typical Application Schematics Bill of Materials Outline Dimensions Ordering Guide
