Datasheet LTC3613 (Analog Devices) - 3
Описание24V, 15A Monolithic Step Down Regulator with Differential Output Sensing
Страниц / Страница36 / 3 — The. ELECTRICAL CHARACTERISTICS. denotes the specifications which apply …
Формат / Размер файлаPDF / 464 Кб
The. ELECTRICAL CHARACTERISTICS. denotes the specifications which apply over the specified operating
The ELECTRICAL CHARACTERISTICS denotes the specifications which apply over the specified operating
27 предложений от 17 поставщиков
Эиком
LTC3613IWKH#PBF
от 3 307 ₽
LTC3613IWKH#TRPBF
TradeElectronics
LTC3613IWKH#TRPBF
Hi-Tech Circuit Group
LTC3613IWKH#PBF
LTC3613
l
denotes the specifications which apply over the specified operating junction temperature range, otherwise specifications are at T + A = 25°C. SVIN = 15V, VFB = VOSNS – VOSNS , unless otherwise noted. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Main Control Loop
VIN Input Voltage Operating Range l 4.5 24 V VOUT Output Voltage Operating Range l 0.6 5.5 V IQ Input DC Supply Current Normal MODE/PLLIN = INTVCC 2 4 mA Shutdown Supply Current RUN = 0V 15 25 μA VREG Regulated Differential Feedback Voltage ITH = 1.2V (Note 3) (V + – OSNS – VOSNS ) TA = 25°C 0.5985 0.6 0.6015 V TA = 0°C to 85°C l 0.596 0.6 0.604 V TA = –40°C to 125°C l 0.594 0.6 0.606 V Regulated Differential Feedback VIN = 4.5V to 24V, ITH = 0.5V to 1.9V, Voltage Over Line, Load and Common Mode V – OSNS = ±500mV (Note 3) (V + – OSNS – VOSNS ) TA = 0°C to 85°C l 0.594 0.6 0.606 V TA = –40°C to 125°C l 0.591 0.6 0.609 V tON(MIN) Minimum On-Time 65 ns tOFF(MIN) Minimum Off-Time 105 ns gm(EA) Error Amplifier Transconductance ITH = 1.2V (Note 3) l 1.4 1.7 2 mS VSENSE(MAX) Valley Current Sense Threshold, VRNG = 2V, VFB = 0.57V l 80 100 120 mV V + – SENSE – VSENSE , VRNG = 0V, VFB = 0.57V l 22 30 38 mV Peak Current = Valley + Ripple VRNG = INTVCC, VFB = 0.57V l 39 50 61 mV V + SENSE(MIN) Minimum Current Sense Threshold,VSENSE – VRNG = 2V, VFB = 0.63V –50 mV V – SENSE , Force Continuous Operation VRNG = 0V, VFB = 0.63V –15 mV VRNG = INTVCC, VFB = 0.63V –25 mV VSENSE(CM) SENSE+, SENSE– Voltage Range (Common l –0.5 5.5 V Mode) ISENSE SENSE+, SENSE– Input Bias Current VSENSE(CM) = 0.6V ±5 ±50 nA VSENSE(CM) = 5V 1 4 μA VRUN(TH) RUN Pin On Threshold VRUN Rising l 1.1 1.2 1.3 V VRUN(HYS) RUN Pin Hysteresis 80 mV ISS Soft-Start Charging Current VTRACKSS = 0V 1.0 μA UVLO INTVCC Undervoltage Lockout Falling l 3.4 3.65 4.0 V INTVCC Undervoltage Lockout Release Rising l 4.2 4.5 V I + + VOSNS VOSNS Input Bias Current VFB = 0.6V ±5 ±25 nA I – – VOSNS VOSNS Input Bias Current VFB = 0.6V –15 –50 μA 3613fa 3
