Datasheet LTC3569 (Analog Devices) - 6
| Производитель | Analog Devices |
| Описание | Triple Buck Regulator with 1.2A and Two 600mA Outputs and Individual Programmable References |
| Страниц / Страница | 26 / 6 — Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. … |
| Формат / Размер файла | PDF / 399 Кб |
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. Buck1 Load Regulation. Buck2 Load Regulation
42 предложений от 21 поставщиков Интегральные микросхемы Силовые чипы — регуляторы напряжения — постоянного тока коммутирующие |
| LTC3569EFE#TRPBF Analog Devices | 187 ₽ | |
| LTC3569EFE#PBF Analog Devices | 253 ₽ | |
| LTC3569EFE#TRPBF Linear Technology | 351 ₽ | |
| LTC3569EFE Linear Technology | по запросу | |
LTC3569
Typical perForMance characTerisTics TA = 25°C, unless otherwise noted. Buck1 Load Regulation Buck2 Load Regulation
0.6 0.6 BUCK2, 3 OFF BUCK1, 3 OFF 0.4 0.4 VIN = 5.5V VIN = 5.5V 0.2 VIN = 4.5V 0.2 VIN = 4.5V PULSE-SKIPPING PULSE-SKIPPING 0.0 0.0 ERROR (%) ERROR (%) V OUT –0.2 VIN = 2.5V V V OUT –0.2 IN = 3.5V VIN = 2.5V VIN = 3.5V –0.4 –0.4 –0.6 –0.6 0 0.2 0.4 0.6 0.8 1 1.2 0 0.1 0.2 0.3 0.4 0.5 0.6 ILOAD (A) ILOAD (A) 3569 G13 3569 G14
Buck3 Load Regulation Line Regulation
0.6 0.15 BUCK1, 2 OFF EACH BUCK TESTED INDIVIDUALLY 0.4 0.10 BUCK2 = 1.2V 0.2 0.05 BUCK1 = 1.8V 0.0 0.00 ERROR (%) ERROR (%) PULSE-SKIPPING V OUT –0.2 V OUT BUCK3 = 1.5V –0.05 –0.4 –0.10 PULSE-SKIPPING MODE ILOAD1 = 200mA VOUT3 = 1.5V ILOAD2, 3 = 150mA –0.6 –0.15 0 0.1 0.2 0.3 0.4 0.5 0.6 2 3 4 5 6 ILOAD (A) VSUPPLY (V) 3569 G15 3569 G16
FB Pin Leakage IQSD vs Temperature
1000 10000 VIN = 5.5V SLAVE VIN = 5.5V 100 DETECTOR = 250nA 1000 10 100 (nA) 1 I (nA) FB2,3 I FB I SVIN 10 0.1 IFB1 1 0.01 0.001 0.1 0 1 2 3 4 5 6 –50 0 50 100 150 VFB (V) TEMPERATURE (°C) 3569 G17 3569 G18 3569fe 6 For more information www.linear.com/LTC3569 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Description Revision History Typical Application Related Parts
