Datasheet LTC3565 (Analog Devices) - 4
Описание | 1.25A, 4MHz, Synchronous Step-Down DC/DC Converter |
Страниц / Страница | 22 / 4 — TYPICAL PERFORMANCE CHARACTERISTICS. TJ = 25°C, VIN = 3.6V, fO = 1MHz, … |
Формат / Размер файла | PDF / 824 Кб |
Язык документа | английский |
TYPICAL PERFORMANCE CHARACTERISTICS. TJ = 25°C, VIN = 3.6V, fO = 1MHz, unless. otherwise noted. Efficiency vs Input Voltage
13 предложений от 13 поставщиков IC REG BUCK ADJ 1.25A 10DFN. Buck Switching Regulator IC Positive Adjustable 0.6V 1 Output 1.25A 10-WFDFN Exposed Pad. PMIC -... |
| LTC3565IDD#TRPBF Analog Devices | 101 ₽ | |
| LTC3565IDD#TRPBF Linear Technology | 216 ₽ | |
| LTC3565IDD#TRPBF Analog Devices | 236 ₽ | |
| LTC3565IDD#TRPBF Analog Devices | 260 ₽ | |
LTC3565
TYPICAL PERFORMANCE CHARACTERISTICS TJ = 25°C, VIN = 3.6V, fO = 1MHz, unless otherwise noted. Efficiency vs Input Voltage Efficiency vs Output Current Efficiency vs Output Current
100 100 100 IOUT = 100mA IOUT = 10mA 90 90 90 80 80 80 70 70 IOUT = 1.25A IOUT = 1mA 70 60 60 50 50 60 40 40 EFFICIENCY (%) EFFICIENCY (%) EFFICIENCY (%) 50 I 30 30 OUT = 0.1mA 20 VIN = 2.7V 20 VIN = 2.7V 40 VIN = 3.6V VIN = 3.6V V 10 V 10 V OUT = 1.8V IN = 4.2V V IN = 4.2V OUT = 1.8V VOUT = 1.5V 30 0 0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 0.1 1 10 100 1000 10000 0.1 1 10 100 1000 10000 INPUT VOLTAGE(V) OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) 3565 G01 3565 G02 3565 G03
Efficiency vs Output Current Efficiency vs Frequency Load Regulation
100 95 1.00 Burst Mode 90 OPERATION 4.7µH 94 80 0.75 70 PULSE 93 SKIP 2.2µH 0.50 60 92 Burst Mode OPERATION 50 0.25 FORCED CONTINUOUS ERROR (%) 40 91 PULSE SKIP EFFICIENCY (%) EFFICIENCY (%) V OUT 30 0.00 90 1µH FORCED CONTINUOUS 20 89 –0.25 10 V VOUT = 1.8V V OUT = 1.8V OUT = 1.8V 0 88 –0.50 0.1 1 10 100 1000 10000 0 1 2 3 4 5 0 200 400 600 800 1000 1200 1400 OUTPUT CURRENT (mA) FREQUENCY (MHz) OUTPUT CURRENT(mA) 3565 G04 3565 G05 3565 G06
Reference Voltage vs Frequency Variation vs Line Regulation Temperature Temperature
0.6 615 6 0.4 610 4 0.2 605 2 TION (%) TAGE (mV) 0.0 ARIA 600 0 ERROR (%) V OUT –0.2 595 –2 REFERENCE VOL FREQUENCY V –0.4 590 –4 VOUT = 1.8V ILOAD = 400mA –0.6 585 –6 2.5 3.0 3.5 4.0 4.5 5.0 5.5 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 INPUT VOLTAGE(V) TEMPERATURE (°C) TEMPERATURE(°C) 3565 G07 3565 G08 3565 G09 3565fc 4 For more information www.linear.com/LTC3565 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Application Package Description Revision History Typical Application Related Parts
