Datasheet LT3500 (Analog Devices) - 3
ОписаниеMonolithic 2A Step-Down Regulator Plus Linear Regulator/Controller
Страниц / Страница28 / 3 — The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 331 Кб
The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over the full operating
The ELECTRICAL CHARACTERISTICS denotes the specifi cations which apply over the full operating
29 предложений от 18 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Линейные и импульсные
Рутоника
LT3500HDD#TRPBF
422 ₽
LT3500HDD#PBF
от 1 117 ₽
Эиком
LT3500HDD#PBF
от 1 204 ₽
LT3500HDD#TRPBF
LT3500
l
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TJ = 25°C. VVIN = 15V, VRT/SYNC = 2V, unless otherwise specifi ed. PARAMETER CONDITIONS MIN TYP MAX UNITS
SHDN Threshold l 710 760 780 mV SHDN Source Current VSHDN = 0.62V 1.5 2.5 3.5 μA SHDN Current Hysterisis 1.25 2 3.25 μA Minimum Input Voltage (Note 3) VFB = 0V l 2.4 2.8 V Supply Shutdown Current VSHDN = 0V l 12 30 μA Supply Quiescent Current VFB = 0.9V 2.5 3.5 mA FB Voltage VVC = 1V l 0.784 0.8 0.816 V VVC = 0.8V to 1.6V, VIN = 3V to 40V l 0.776 0.8 0.824 V FB Bias Current VFB = 0.8V, VVC = 1V 50 150 nA Error Amplifi er gm VVC = 1V, IVC = ±10μA 150 250 350 μmho Error Amplifi er Source Current VFB = 0.6V, VVC = 1V 12 16 20 μA Error Amplifi er Sink Current VFB = 1V, VVC = 1V 14 18 22 μA Error Amplifi er High Clamp VFB = 0.6V 1.8 2.0 2.2 V Error Amplifi er Switching Threshold VFB = 0.6V 0.6 0.8 1.0 V SS Source Current VSS = 0.4V, VFB = 0.9V 2.25 2.75 3.75 μA SS Sink Current VFB = 0V, VSS = 2V 300 600 900 μA SS POR Sink Current (Note 4) VFB = 0V, VSS = 2V, Cycle SHDN 400 600 800 μA SS POR Threshold 50 100 150 mV SS to FB Offset (VSS – VFB) VVC = VFS, VSS = 0.4V 70 100 120 mV PG/PG Leakage VFB = 0.9V, VPG/VPG = 40V 0.1 1 μA PG/PG Threshold (Rising) VPG = 0.4V 0.685 0.708 0.730 V PG/PG Hysteresis (Falling) VPG = 0.4V 20 30 40 mV PG Sink Current VPG = 0.4V, VFB = 0.7V 250 500 750 μA PG Sink Current VPG = 0.4V, VFB = 0.9V 500 800 1100 μA RT/SYNC Reference Voltage VFB = 0.9V, RRT/SYNC = 15k 0.75 0.850 0.975 V Switching Frequency RRT/SYNC = 90.9k 450 500 550 kHz RRT/SYNC = 90.9k l 425 500 625 kHz RRT/SYNC = 15k 2 2.4 2.8 MHz SYNC Frequency Range l 250 2500 kHz Minimum Switch On Time VFB = 0.7V, RRT/SYNC = 90.9k 140 ns Minimum Switch Off Time VFB = 0.7V, RRT/SYNC = 90.9k 120 ns Switch Leakage Current VSW = 0V 1 10 μA Switch Saturation Voltage ISW = 2A, VBST = 18V, VFB = 0.7V 450 mV Switch Peak Current DD Package VBST = 18V, VFB = 0.7V 2.3 2.8 3.5 A l 2.1 2.8 3.5 A Switch Peak Current MSE Package VBST = 18V, VFB = 0.7V 2.3 2.9 3.5 A l 2.1 2.9 3.7 A Boost Current ISW = 2A, VBST = 20V, VFB = 0.7V 20 30 45 mA Minimum Boost Voltage (Note 5) ISW = 2A, VFB = 0.7V 2.2 3 V 3500fc 3
