Datasheet LTC3544 (Analog Devices) - 3
| Производитель | Analog Devices |
| Описание | Quad Synchronous Step-Down Regulator: 2.25MHz, 300mA, 200mA, 200mA, 100mA |
| Страниц / Страница | 16 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply … |
| Формат / Размер файла | PDF / 300 Кб |
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
13 предложений от 13 поставщиков IC REG BUCK ADJ QD 16QFN. Buck Switching Regulator IC Positive Adjustable 0.8V 4 Output 100mA, 200mA(2), 300mA 16-WFQFN Exposed Pad.... |
| LTC3544EUD#TRPBF Analog Devices | 129 ₽ | |
| LTC3544EUD#TRPBF Linear Technology | 322 ₽ | |
| LTC3544EUD-TRPBF
| по запросу | |
| LTC3544EUD#TRPBF Linear Technology | по запросу | |
LTC3544
ELECTRICAL CHARACTERISTICS The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 3.6V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IS Input DC Bias Current Active Mode VFB = 0.7V, ILOAD = 0A, 2.25MHz 825 1100 μA (Four Regulators Enabled) Sleep Mode VFB = 0.9V, ILOAD = 0A, 2.25MHz 70 80 μA (Four Regulators Enabled) Shutdown 0.1 2 μA fOSC Oscillator Frequency VIN = 3V 2.25 MHz VIN = 2.5V to 5.5V ● 1.8 2.7 MHz VRUN(HIGH) RUNx Input High Voltage ● 1.0 V VRUN(LOW) RUNx Input Low Voltage ● 0.3 V ISWx SWx Leakage VRUN = 0V, VSW = 0V or 5.5V, VIN = 5.5V ±0.1 ±1 μA IRUNx RUN Leakage Current VIN = 5.5V ● ±0.1 ±1 μA IVFBx VFBx Leakage Current 80 nA tSS Soft-Start Period VFB = 7.5% to 92.5% Full Scale 650 875 1200 μs VUVLO Undervoltage Lockout ● 1.9 2.25 V
Individual Regulator Characteristics Regulator SW300 – 300mA
IPK Peak Switch Current Limit VFB < VFBREG, Duty Cycle < 35% 400 600 800 mA IS300 Input DC Bias Current–Reg SW300 Only VFB = 0.9V, ILOAD = 0A, 2.25MHz 32 μA Burst Mode Operation (Sleep) RPFET RDS(ON) of P-Channel FET (Note 7) ISW = 100mA 0.55 Ω RNFET RDS(ON) of N-Channel FET (Note 7) ISW = –100mA 0.50 Ω
Regulator SW200A – 200mA
IPK Peak Switch Current Limit VFB < VFBREG, Duty Cycle < 35% 300 400 500 mA IS200 Input DC Bias Current–Reg SW200A Only VFB = 0.9V, ILOAD = 0A, 2.25MHz 32 μA Burst Mode Operation (Sleep) RPFET RDS(ON) of P-Channel FET (Note 7) ISW = 100mA 0.65 Ω RNFET RDS(ON) of N-Channel FET (Note 7) ISW = –100mA 0.60 Ω
Regulator SW200B – 200mA
IPK Peak Switch Current Limit VFB < VFBREG, Duty Cycle < 35% 300 400 500 mA IS200 Input DC Bias Current–Reg SW200B Only VFB = 0.9V, ILOAD = 0A, 2.25MHz 32 μA Burst Mode Operation (Sleep) RPFET RDS(ON) of P-Channel FET (Note 7) ISW = 100mA 0.65 Ω RNFET RDS(ON) of N-Channel FET (Note 7) ISW = –100mA 0.60 Ω
Regulator SW100 – 100mA
IPK Peak Switch Current Limit VFB < VFBREG, Duty Cycle < 35% 200 300 400 mA IS100 Input DC Bias Current–Reg SW100B Only VFB = 0.9V, ILOAD = 0A, 2.25MHz 32 μA Burst Mode Operation (Sleep) RPFET RDS(ON) of P-Channel FET (Note 7) ISW = 100mA 0.80 Ω RNFET RDS(ON) of N-Channel FET (Note 7) ISW = –100mA 0.75 Ω
Note 1:
Note 2:
The LTC3544E is guaranteed to meet performance specifi cations may cause permanent damage to the device. Exposure to any Absolute from 0°C to 85°C. Specifi cations over the –40°C to 85°C operating Maximum Rating condition for extended periods may affect device temperature range are assured by design, characterization and correlation reliability and lifetime. with statistical process controls. 3544fa 3
