Datasheet LTC3611 (Analog Devices) - 3
Описание10A, 32V Monolithic Synchronous Step-Down DC/DC Converter
Страниц / Страница26 / 3 — The. denotes the specifications which apply over the full operating
Формат / Размер файлаPDF / 426 Кб
The denotes the specifications which apply over the full operating
14 предложений от 14 поставщиков
IC REG BUCK ADJUSTABLE 10A 64QFN. Buck Switching Regulator IC Positive Adjustable 0.6V 1 Output 10A 64-PowerVFQFN. PMIC - Voltage Regulators...
LTC3611EWP#TRPBF
971 ₽
Рутоника
LTC3611EWP#TRPBF
984 ₽
LTC3611EWP#TRPBF
1 829 ₽
LTC3611EWP#TRPBF
LTC3611 e lectricAl chArActeristics
The
l
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VIN = 15V unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Main Control Loop
VIN Operating Input Voltage Range 4.5 32 V IQ Input DC Supply Current Normal 900 2000 µA Shutdown Supply Current 15 30 µA VFB Feedback Reference Voltage ITH = 1.2V (Note 3) –40°C to 85°C 0.594 0.600 0.606 V –40°C to 125°C l 0.590 0.600 0.610 V ΔVFB(LINEREG) Feedback Voltage Line Regulation VIN = 4V to 30V, ITH = 1.2V (Note 3) 0.002 %/V ΔVFB(LOADREG) Feedback Voltage Load Regulation ITH = 0.5V to 1.9V (Note 3) –0.05 –0.3 % IFB Feedback Input Current VFB = 0.6V –5 ±50 nA gm(EA) Error Amplifier Transconductance ITH = 1.2V (Note 3) l 1.4 1.7 2 mS VFCB Forced Continuous Threshold l 0.54 0.6 0.66 V IFCB Forced Continuous Pin Current VFCB = 0.6V –1 –2 µA tON On-Time ION = 60μA, VON = 1.5V 190 250 310 ns ION = 60μA, VON = 0V 120 ns tON(MIN) Minimum On-Time ION = 180μA, VON = 0V 60 100 ns tOFF(MIN) Minimum Off-Time ION = 30μA, VON = 1.5V 290 500 ns IVALLEY(MAX) Maximum Val ey Current VRNG = 0V, VFB = 0.56V, FCB = 0V l 6 10 A VRNG = 1V, VFB = 0.56V, FCB = 0V l 8 15 A IVALLEY(MIN) Maximum Reverse Val ey Current VRNG = 0V, VFB = 0.64V, FCB = 0V –6 A VRNG = 1V, VFB = 0.64V, FCB = 0V –8 A ΔVFB(OV) Output Overvoltage Fault Threshold 7 10 13 % VRUN/SS(ON) RUN Pin Start Threshold l 0.8 1.5 2 V VRUN/SS(LE) RUN Pin Latchoff Enable Threshold RUN/SS Pin Rising 4 4.5 V VRUN/SS(LT) RUN Pin Latchoff Threshold RUN/SS Pin Fal ing 3.5 4.2 V IRUN/SS(C) Soft-Start Charge Current VRUN/SS = 0V –0.5 –1.2 –3 µA IRUN/SS(D) Soft-Start Discharge Current VRUN/SS = 4.5V, VFB = 0V 0.8 1.8 3 µA VIN(UVLO) Undervoltage Lockout VIN Fal ing l 3.4 3.9 V VIN(UVLOR) Undervoltage Lockout Release VIN Rising l 3.5 4 V RDS(ON) Top Switch On-Resistance 15 22 mΩ Bottom Switch On-Resistance 9 14 mΩ 3611fd Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration order information Electrical Characteristics Typical Performance Characteristics Pin Functions Functional Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
