Datasheet LTC3415 (Analog Devices) - 3
Описание7A, PolyPhase Synchronous Step-Down Regulator
Страниц / Страница28 / 3 — The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply …
Формат / Размер файлаPDF / 322 Кб
The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over the full operating
The ELECTRICAL CHARACTERISTICS denotes the specifi cations which apply over the full operating
32 предложений от 15 поставщиков
IC REG BUCK ADJ 7A SYNC 38QFN / Conv DC-DC 2.5V to 5.5V Synchronous Step Down Single-Out 0.6V to 5.5V 7A...
727GS
LTC3415EUHF#TRPBF
1.58 ₽
LTC3415EUHF#TRPBF
382 ₽
IC Home
LTC3415EUHF#TRPBF
1 206 ₽
LTC3415EUHF TRPBF
LTC3415
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VIN = 3.3V unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IQ Input DC Bias Current (Note 4) Active Current VFB = 0.57V, MODE = 0V 1350 μA Sleep VFB = 0.63V, MODE = VIN 450 μA Shutdown VRUN = 0V 0.2 5 μA fOSC Switching Frequency 1.3 1.5 1.7 MHz fSYNC SYNC Capture Range 0.75 2.25 MHz RPFET RDS(ON) of P-Channel FET ISW = 100mA 32 40 mΩ RNFET RDS(ON) of N-Channel FET ISW = 100mA 25 32 mΩ ILIMIT Peak Current Limit VITH = 1V (Note 6) 11 13 15 A VUVLO Undervoltage Lockout Threshold SVIN Rising 2.05 2.2 2.35 V SVIN Falling 1.85 2.0 2.15 V ILSW SW Leakage Current VRUN = 0V, VIN = 5.5V 0.1 5 μA SS Delay Internal Soft-Start Delay 140 μs gm Error Amplifi er’s Transconductance 1.7 2 2.2 mmho RUN Run Input Threshold RUN Rising 1.4 1.5 1.6 V RUN Falling 1.2 1.3 1.4 V PGOOD Delay PGOOD Falling Edge Delay 35 μs %MARGINING Output Voltage Margining Percentage MGN HI, BSEL LOW 3 5 7 % MGN HI, BSEL HI 8 10 12 % MGN HI, BSEL = SVIN/2 13 15 17 % MGN LOW, BSEL LOW –3 –5 –7 % MGN LOW, BSEL HI –8 –10 –12 % MGN LOW, BSEL = SVIN/2 –13 –15 –17 % TRACK Tracking Threshold (Rising) RUN = VIN 0.57 V Tracking Threshold (Falling) RUN = 0V 0.18 V Tracking Disable Threshold VIN – 0.5 V VFB Slavemode VFB Slavemode (EA Disable) Threshold VIN – 0.5 V ITH Internal Switch Over Threshold for Internal VIN – 0.5 V Compensation OV Output Overvoltage Threshold VFB Rising 7 10 13 % UV Output Undervoltage Threshold VFB Falling –7 –10 –13 % VHYST OV/UV Hysteresis VFB Returning to Regulation 1 3 %
Note 1:
Note 5:
TJ is calculated from the ambient temperature TA and power may cause permanent damage to the device. Exposure to any Absolute dissipation as follows: LTC3415: TJ = TA + PD (34°C/W). Maximum Rating condition for extended periods may affect device
Note 6:
Current Limit is measured with internal servo loop while forcing reliability and lifetime. VITH = 1V.
Note 2:
The LTC3415E is guaranteed to meet performance specifi cations
Note 7:
This IC includes overtemperature protection that is intended from 0°C to 85°C. Specifi cations over the –40°C to 85°C operating to protect the device during momentary overload conditions. Junction temperature range are assured by design, characterization and correlation temperature will exceed 125°C when overtemperature protection is active. with statistical process controls. Continuous operation above the specifi ed maximum operating junction
Note 3:
The LTC3415 is tested in a feedback loop that adjusts VFB to temperature may impair device reliability. achieve a specifi ed error amplifi er output voltage (ITH).
Note 4:
Dynamic supply current is higher due to the internal gate charge being delivered at the switching frequency. 3415fa 3
